-   -   Can you ridge vents 3:12? 2x15lb or 2x30lb (http://www.diychatroom.com/f9/can-you-ridge-vents-3-12-2x15lb-2x30lb-126701/)
MB1 12-15-2011 01:05 PM
I just had two different roofing companies bid my house for a new roof. One says they will not (and cannot anyways) put in ridge venting given a 3:12 roof. They say it is prone to leaking with wind driven rain. The other says they do it all the time and use the best system on the market called Shingle Vent 2. Which do you recommend?
Also, given that I am in San Jose, CA is it worthwhile going 2 x 30# felt or is 2 x 15# sufficient on a 30 year certainteed landmark shingle? (BTW, I am somewhat concerned about adding too much additional weight on my roof)
Thank you,
Marcum
titanoman 12-15-2011 01:32 PM
Thank you,
Marcum
I would think ridge caps could leak, unless they have some product out there for shallow pitches.
What do you mean "2x" the felt? I would think 1 layer of 30lb.
Sent from a Samsung Galaxy S2
MB1 12-15-2011 01:53 PM
By 2x I meant two layers. I spoke with an inspector who said 2 layers have to be used. It can't be one layer of 30# in lieu of 2 layers of 15#. Is the two layers of 30# overkill and will it add much more weight than the 15#?
titanoman 12-15-2011 02:00 PM
It's a Cali thing I guess. And it's no extra weight compared to the weight of the shingles themselves anyway.
Do you doubt the soundness of the structure for some reason?
MB1 12-15-2011 04:27 PM
Well, I have 2x2 inch engineered trusses 24" on center. All the roofers who have walked it say it's solid and they do not feel deflection, but it currently has a 20 year 200 lb per square shingle and a thin single layer of craft type paper with thin tar as an underlayment (and 1/2 or 5/8" OSB). The Landmark is 265lb/sq, and 2 layers of #15 will add to what I have as well. Maybe the 15# vs 30# difference is nothing to worry about. I just don't want to overload it. From what I hear from the inspector, 30 year is very common for re-roofs of these.
titanoman 12-15-2011 05:00 PM
2x2 trusses? Anyway, you should be fine.
Are they going over what's there or stripping the old roof?
AndyGump 12-15-2011 05:14 PM
R905.2.7 Underlayment application. For roof slopes from two units vertical in 12 units horizontal (17-percent slope), up to four units vertical in 12 units horizontal (33-percent slope), underlayment shall be two layers applied in the following manner. Apply a 19-inch (483 mm) strip of underlayment felt parallel to and starting at the eaves, fastened sufficiently to hold in place. Starting at the eave, apply 36-inch-wide (914 mm) sheets of underlayment, overlapping successive sheets 19 inches (483 mm), and fastened sufficiently to hold in place. Distortions in the underlayment shall not interfere with the ability of the shingles to seal. For roof slopes of four units vertical in 12 units horizontal (33-percent slope) or greater, underlayment shall be one layer applied in the following manner. Underlayment shall be applied shingle fashion, parallel to and starting from the eave and lapped 2 inches (51 mm), fastened sufficiently to hold in place. Distortions in the underlayment shall not interfere with the ability of the shingles to seal. End laps shall be offset by 6 feet (1829 mm).
From the 2010 CRC.
Andy.
tinner666 12-15-2011 05:37 PM
"but it currently has a 20 year 200 lb per square shingle and a thin single layer of craft type paper with thin tar as an underlayment (and 1/2 or 5/8" OSB). The Landmark is 265lb/sq, and 2 layers of #15 will add to what I have as well."
You make it sound like they aren't going to tear the exiting roof off.
I wouldn't even consider roofing over the existing.
Tear it off! And the Landmarks and felt won't add much weight.
I apologize in advance if I read this wrong.
joecaption 12-15-2011 05:41 PM
This has to be a manufactured home, no real house would have 2 X 2's for trusses.
titanoman 12-15-2011 05:41 PM
That's why I wrote post #6.
MJW 12-15-2011 05:48 PM
With the way the roofing is described, I'm thinking manufactured home also.
FWIW, shinglevent 2 is not the the best on the market. I have pics of it failing within 15 years.
Windows on Wash 12-15-2011 08:21 PM
What is your favorite?
tinner666 12-15-2011 09:04 PM
Yeah, I see I missed that one. :)
For Joecaption and MJW, he said it was a triple-wide in an earlier thread. This subject spans 2 - 3 threads.
This one mentions the home being a triple-wide.
http://www.diychatroom.com/f9/why-le...le-osb-126477/
http://www.diychatroom.com/f9/weathe...-first-126705/
MB1 12-15-2011 09:07 PM
Thank you for all the comments and sorry for the confusion I created. Yes, this is a manufactured home about 2000 sq ft, triple wide. Pictures per my post here: http://www.diychatroom.com/f9/help-w...roblem-126559/. I am definitely stripping off all the old material down to the sheething.
Will also use Winterguard in the dormer valleys, under the dormers, and around all critical areas. And, will skip the ridge venting although will likely add gable venting (unless someone thinks that isn't a good idea?)
Thank you,
Marcum
MJW 12-16-2011 07:43 AM
Omni roll. No baffles to clog up, completely open NFA.
