Can You Put Dimensional Shingles On A Grabrel / Mansard Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 02:34 PM   #1
Question
Can you put dimensional shingles on a grabrel / mansard roof?
We took a lot of wind damage recently to our dutch colonial home. I'm still a little confused on if this roof is considered a mansard or a gambrel roof. It has the upper angled portion that meets and a peak and the lower portion comes down at almost a straight angle with 3 dormer windows sticking out.Has that barn kinda look to it. Anyway the last roof was a 30 year 3 tab shingle. It lasted 10 years before the wind tore it up. I'm entertaining a dimensional shingle since I hear they hold up to wind much better but I have been told they don't look right or lay right on my type of roof. Is that true? Thanks
mommiemara is offline   Reply With Quote
Old 07-31-2012, 02:40 PM   #2
Rewards Points: 13,300
It's done all the time. Lot's of store fronts are done this way.
You have pay special attenion to the directions when nailing them.
There made in 2, layers if there not nailed in the right area the two sepperate and come apart.
Old 07-31-2012, 10:18 PM   #3
Doing This Way Too Long
Rewards Points: 532
Yes, but make sure it is 6-nailed and nailed properly on the nail strip. Will hold up great. Have seen many that gravity releases the back laminate and it falls out.
OldNBroken is offline   Reply With Quote
Old 07-31-2012, 11:42 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,994
+1
Works just fine. Minimum 6 nails and they should be hand sealed.
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 08:50 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Should I replace my roof? skittlebear Roofing/Siding 8 04-10-2010 07:01 PM
Need new Roof Shingles larrylwill Roofing/Siding 5 12-16-2009 11:26 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
