Can Someone Help Me Identify These Shingles? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2011, 10:19 AM   #1
Rewards Points: 37
Can someone help me identify these shingles?
I'm wondering what type of shingles these are. You may not be able to tell from the picture, but the dimension of each shingle is approx. 24" long, 3-4" exposed. These aren't 3 tab, it's almost like a single tab shingle, for lack of a better word.
I'm wondering who makes/made these, and if I can still buy them. Thanks!
Edit: Link to photo:
https://picasaweb.google.com/1014272...eat=directlink
SoxFan44 is offline   Reply With Quote
Old 08-25-2011, 08:46 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
That shingle is a standard strip shingle (3-tab) without the cutouts.
Also known as a "No cutout" shingle.They are a 25yr shingle.
The only manufacture and brand I have used is the CertainTeed Jet 25.
Your roof looks like it was a rack installation.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
SoxFan44 (08-26-2011)
Old 08-26-2011, 08:02 AM   #3
Rewards Points: 37
Thanks for the help, just one more question. What do you mean by a 'rack installation'?
Old 08-26-2011, 03:27 PM   #4
RFN-4A-LVN
IMO your shingles resemble the dimensional since the cutouts have not been removed creating the bond lines like the traditional strip shingle (3-tab)then it should be stair stepped like the dimensional architecture style shingle.
Running your shingles straight up the roof in columns, is called "racking". It has been around as long as there have been three-tabs, which were designed to be lined up nice and straight.
When they're not, they look just awful and you don't have to be an expert to notice it. Even your neighbor, (who doesn't know anything about roofing), knows those tabs are supposed to be straight!
Racking is the best way to keep them straight. When a shingle is out of alignment, it is easy to spot and can be corrected on the very next column.
But manufacturers' don't like racking. This goes back to the days when quality control of the granule colors wasn't as good as it is now. Slight variations in shading were less apparent when the stair step method was used, so that is what they specified then, and they still do,
Although racking is a common trade practice, it occasionally becomes an issue.The rack method shows a pattern with the vertical method and IMO they blend much better stair stepped.
For a strip shingle to be racked the start row that runs vertical would have a 6" offset.The installer would run each row verticle the entire way across the roof.
Some material calls for a rack method but those are generally your premium high end shingles.
SoxFan44 (09-08-2011)
Old 09-08-2011, 04:01 PM   #5
RoofMaster nails another one.
BCIDallas is offline   Reply With Quote
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
