Can See Outside At Chimney / Roof Line - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 12:59 PM   #16
Originally Posted by mickey cassiba View Post
Post the guys name on "Angie's List" or something similar...he's rippin' you off, and likely has ripped off many before.
Just my two cents...
This guy has actually won awards from Angie's List. I cannot find a single negative review about him online. His worst reviews are 4/5 and say how great he was.
indianaftw is offline   Reply With Quote
Old 03-23-2011, 01:14 PM   #17
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Just need to get a roofer to re-flash it. That's total reliance on clear sealant there.
tinner666 is offline   Reply With Quote
Old 03-23-2011, 08:26 PM   #18
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
That is a poor flashing job, but it's not unusual to be able to see some daylight where the flashing overlaps the masonry, especially with copper.
seeyou is offline   Reply With Quote
Old 03-24-2011, 06:59 AM   #19
I predict you will have a leak the next rain and not be a happy camper. That is just sloppy work. By redoing your fireplace, they should of re-flashed it as well. For a few dollars more, things would of looked so much better. They didn't even paint it. Wow....
www.springtxroofingcontractors.com
springtxroofing is offline   Reply With Quote
Old 03-24-2011, 08:40 AM   #20
mem
Rewards Points: 156
Yes, that is a horrible flashing job. It needs to be redone properly. Was that chimney crown part a the rebuild you just had? That looks to be a hack job as well! It appears to be falling apart already. And what's with that flue?
mem is offline   Reply With Quote
Old 03-25-2011, 02:39 PM   #21
The chimney was a part of the rebuild. What is wrong with the flue so I can speak to them about it.
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 08:46 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Heading off roof rafters for chimney pipe. jrcurto Roofing/Siding 1 10-28-2008 04:25 PM
Leaks around chimney after new roof was put on proofer Roofing/Siding 25 04-22-2008 01:31 AM
