Can See Outside At Chimney / Roof Line - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-22-2011, 05:05 PM   #1
Can see outside at Chimney / roof line
So I just had my chimney rebuilt and when I went to the attic, there were about 5 spots where I could see daylight where the brick meets the roof line. I could actually see outside of my house. So I spoke to the guy that did it and they came out and said it was fixed.
Their fix was just gobbing a bunch of caulk into the gaps. Even with the caulk, I can still see spots where they missed.
Should this be happening? To me, it doesn't sound right at all.
Should they put up all new flashing?
indianaftw is offline   Reply With Quote
Old 03-22-2011, 05:29 PM   #2
kwikfishron's Avatar
Rewards Points: 172
No that should not be happening.
Can you post a picture or two from the outside?
How to attach a photo to a post
kwikfishron is offline   Reply With Quote
Old 03-22-2011, 05:57 PM   #3
DIY staff
Rewards Points: 7,174
Definitely get those holes sealed----You will be infested with Yellow Jackets.
Old 03-22-2011, 06:08 PM   #4
Rewards Points: 172
If its all flashed properly there should be no holes to seal.
Old 03-22-2011, 07:51 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Does anyone care about pride of workmanship anymore? Goop and smear's? Yeah that will fix it
Tar and sealants are a roofs version of duct tape a.k.a Arkansas chrome.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
kwikfishron (03-22-2011)
Old 03-22-2011, 07:54 PM   #6
Rewards Points: 172
Till the check clears anyway.
Old 03-22-2011, 08:09 PM   #7
That is exactly what I was thinking. I have told him that I want the flashing redone.
Old 03-22-2011, 08:42 PM   #8
Rewards Points: 172
Post some pictures if you want detailed info on what should be done.
Old 03-22-2011, 09:06 PM   #9
just a tool guy
mickey cassiba's Avatar
Post the guys name on "Angie's List" or something similar...he's rippin' you off, and likely has ripped off many before.
Just my two cents...
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 03-22-2011, 09:10 PM   #10
Horrible advice.
BamBamm5144 is offline   Reply With Quote
Old 03-22-2011, 09:12 PM   #11
just a tool guy
Originally Posted by BamBamm5144 View Post
Horrible advice.
Sorry you feel that way, but I feel like jack legs should be outed every time they rear their heads. Back in the old days when I was a framing carpenter(licensed., bonded and registered) when we caught guys pushing crap work, we took 'em down the road and, well use your imagination. There are lots of reputable, responsible craftsmen out there...no reason that some unethical folks should make it hard for everyone else.
But as I said...just my two cents.
Mickey
Old 03-22-2011, 09:22 PM   #12
There are two sides to every story. Could be something more.
It would be more effective to get opinions of other contractors. We haven't even seen pictures yet.
The Following User Says Thank You to BamBamm5144 For This Useful Post:
Roofmaster417 (03-22-2011)
Old 03-23-2011, 01:55 PM   #13
Here are some pics... More are on the way... The first pics are from the inside and it's hard to take a picture with my camera indoors.
Can see outside at Chimney / roof line-chimney3.jpg   Can see outside at Chimney / roof line-chimney5.jpg   Can see outside at Chimney / roof line-chimney7.jpg   Can see outside at Chimney / roof line-chimney9.jpg   Can see outside at Chimney / roof line-chimney10.jpg
Can see outside at Chimney / roof line-chimney16.jpg
Old 03-23-2011, 01:56 PM   #14
More Pics...
Can see outside at Chimney / roof line-chimney17.jpg   Can see outside at Chimney / roof line-chimney18.jpg   Can see outside at Chimney / roof line-chimney20.jpg   Can see outside at Chimney / roof line-chimney22.jpg   Can see outside at Chimney / roof line-chimney23.jpg
Can see outside at Chimney / roof line-chimney26.jpg
Old 03-23-2011, 01:57 PM   #15
Last pic of the top.
I took a bunch more pics. But hopefully you guys can give me some advice on what my next steps should be in this situation.
Thanks again!
Can see outside at Chimney / roof line-chimney28.jpg
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 09:46 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Heading off roof rafters for chimney pipe. jrcurto Roofing/Siding 1 10-28-2008 05:25 PM
Leaks around chimney after new roof was put on proofer Roofing/Siding 25 04-22-2008 02:31 AM
