Can A Roof Over Be Done Over Felt? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-21-2013, 10:48 AM   #1
Question
can a roof over be done over felt?
My roof is ROTTEN and I have a limited amount to work with. All the plywood on the roof has to be replaced, that's easy enough to do but I want to do a roof over vs laying out shingles because I also have limited amount of manpower. Can I do a roofover just felt or would I have to put rolled roofing over the felt BEFORE doing the roofover.
Mrs Pat is offline   Reply With Quote
Old 06-21-2013, 11:45 AM   #2
jproffer's Avatar
Rewards Points: 716
So your plywood is rotten but you want to do a layover?
And with just felt?
I wouldn't recommend that one.
jproffer is offline   Reply With Quote
Old 06-21-2013, 12:12 PM   #3
Old School
Willie T's Avatar
If the plywood is being replaced, where are you finding the original shingles to roof over? You putting them back on?
Willie T
Old 06-21-2013, 02:23 PM   #4
Roofmaster
Rewards Points: 2,210
Your statement makes no sense whatsoever. Please read it and restate what you are attempting to do.
Old 06-21-2013, 04:07 PM   #5
Darryl Mathe's Avatar
Yup, a real head scratcher for me too. What is you say?
Darryl Mathe is offline   Reply With Quote
Old 06-21-2013, 06:24 PM   #6
clarification
the ROOF OVER I meant involves furring strips and a corrugated roofing material not roofing shingles which was stated. so....
1.) remove and replace plywood. not saving shingles.
2.) put roofing felt down.
3.) placing furring strips down. (some people say use them some say no. I'd rather but.......)
4.) putting down corrugated roofing material. or a metal roofing material
I'm sorry I can't get more simplistic than that.
Does that help?
I have no choice I have to do this myself I literally can't afford to have someone do it so thanks for the help. If i state things wrong read between the lines and I have watched people do it but never done it myself so you can call me a nit wit but ya gotta do whatcha gotta do
Old 06-21-2013, 06:55 PM   #7
"the ROOF OVER I meant involves furring strips and a corrugated roofing material not roofing shingles which was stated..."
No, it wasn't
RoyalAcresRod is offline   Reply With Quote
The Following 2 Users Say Thank You to RoyalAcresRod For This Useful Post:
Gymschu (06-21-2013), jproffer (06-22-2013)
Old 06-21-2013, 07:21 PM   #8
Gymschu's Avatar
Rewards Points: 932
If you are trying to do a metal roof by yourself, I hope your insurance premiums are up to date.
Gymschu is online now   Reply With Quote
Old 06-21-2013, 07:53 PM   #9
Roofmaster
OK I think I get you now. Your first post said nothing about metal or corrugated whatsoever, so copping a haughty attitude is not warranted.
I would not recommend this type of roof for your home, as you will probably get some leaks now and then but if it is for a chicken coop or shed or something like that then it would be OK.
1. Re-Sheathe with plywood.
2. Install ASTM D-226, Type 2 (No. 30) Felt. Make sure the felt has the ASTM number. side lap 3 inches and end lap 6 inches. I would put mastic in the end laps.
3. Install furring strips so they fall in the ribs. About 1 foot on center.
4. Fasten panels into top of ribs with No. 14 HWH self tapping screws with EPDM sealing washers. Side lap 2 ribs with sealant, end lap 6 inches.
Old 06-21-2013, 10:06 PM   #10
Lord of Slums
Rewards Points: 1,974
Shingles would be cheaper and easier. Metal roofing is not easy to do properly. I could see how it would be very dangerous as well. Oh, by yourself, no, I would not try that
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
jagans (06-21-2013)
Old 06-22-2013, 09:04 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
While I love metal, as a homeowner undertaking, it is the more difficult application to get done properly.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Gymschu (06-22-2013), roofingquotes (06-22-2013)
Old 06-22-2013, 11:25 PM   #12
roofingquotes's Avatar
I like metal roofing too. But I would not recommend it done with a newbie.
roofingquotes is offline   Reply With Quote
Old 06-23-2013, 02:46 PM   #13
Metal Roofing
Rewards Points: 600
In lieu of metal why not do comp, it is easier to install for the diy inclined and cheaper and easier to install than metal. DIY is great for a lot of things, but i would not be risking a DIY job on a metal roof, your just asking for problems. We havent seen your roof but generally Metal is not DIY. So unless your roof is two sides, no hips no valley and no penatrations () Comp is the smart move...or hire a metal roofer.
AndyWRS is offline   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
In desperate need of professional help photosbyvj Roofing/Siding 50 07-26-2009 05:57 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
