Can I Use Architectural Shingles For Starter Row ?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-20-2012, 04:28 PM   #1
Can I use architectural shingles for starter row ??
I was given some Pinnacle Pristine 30 year dimensional shingles. Can I use these for the starter row ??
Roofing Project is offline   Reply With Quote
Old 03-20-2012, 04:41 PM   #2
Doing This Way Too Long
Rewards Points: 532
CAN you? Yes, but it's not correct. Should you? NO! That is why they have starter...or 3-tab
OldNBroken is offline   Reply With Quote
Old 03-20-2012, 05:42 PM   #3
Ok.. I mean I'm not trying to half ass it but we are looking to cut costs wherever we can
Old 03-20-2012, 05:51 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Buy 3-tabs and cut the tabs off so you have an 8" piece left. Nail it right side up, as low down as there is wood to nail so the sealer strip locks your shingles down.
tinner666 is offline   Reply With Quote
Old 03-20-2012, 06:00 PM   #5
Gymschu's Avatar
Rewards Points: 486
Starter strips are inexpensive. Usually 33 ft for about $12. Sure makes it a lot easier IMO.
Old 03-20-2012, 06:01 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Not worth cheaping out on that.
Starters are just as cheap as 3-Tabs around here now.
Old 03-20-2012, 08:16 PM   #7
Gotcha...Thanks to everyone! This site has really helped out !!
Old 03-20-2012, 09:07 PM   #8
MJW
I've seen entire complexes (100's of squares) done without a single real starter. They cut the laminated part off the timberlines and used the top portion for starters. This is a very high dollar and highly promoted exterior company in our region also. They also use all sub-contractors that are not necessarily living in our region, if you know what I mean.
Is it right though? Absolutely not. Does anyone notice besides another person in the trades? I'll bet not.
MJW is offline   Reply With Quote
Old 03-20-2012, 09:18 PM   #9
ParagonEx's Avatar
Rewards Points: 150
The time you save using premade starters more than pays for itself.
ParagonEx is offline   Reply With Quote
Old 03-20-2012, 09:23 PM   #10
Pro Slate Roofer
tinner666's Avatar
Did they ever change the size of those? I only bought them once, years ago, and they were 6" wide giving a 1" headlap. I took them back and bought 3-tabs. I have never checked them since, so I'm just curious. I want the 3" headlap of an 8" 3-tab on the eave to help with ice dam issues.
Architectural shingles to buy vs. regular vkerns Roofing/Siding 24 08-04-2016 05:31 PM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 08:50 PM
how to make ridge cap shingles with tabless architectural shingles kw151002 Roofing/Siding 3 07-10-2009 08:15 AM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 07:50 AM
reg. or Architectural shingles? fricandfrac Building & Construction 6 04-02-2009 05:47 PM
