Can I Remove End Box - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-14-2010, 06:37 AM   #1
Sweetafton
Send a message via MSN to Sweetafton
Can I remove End Box
On my house the soffit and facia were covered with pvc afew years ago. At the time i was assured all rotten wood would be repaired or replaced. I have recently discovered non of the wood was replaced. So I have three end boxes with rotten wood. Can I remove the end boxes, and have the barge board just meet the soffit and facia at the gable end.
Sweetafton is offline   Reply With Quote
Old 08-14-2010, 12:50 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Sweetafton, I am not exactly clear on what you want to do. The barge fascia runs down and connects with the front and rear fascia, the bird box covers the end of the cornice where the two fascias meet. Removing the bird box will expose the open end of the soffit and not look good. Is that what you wanted to do?
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-14-2010, 02:51 PM   #3
Sweetafton
On the gable end is a barge and a soffit which go down to the corner of the house, which meet up with the facia and soffit on the front of the house. Where all these meet at the corner of the house at wall plate level is the end box, which seems to me as a large empty space, with a frame which in my case is rot.
Instead of replacing the end box, can i not just run the barge board down to meet the facia and the two soffits meet at the corner. What i am really asking is there any need for the end box.
Old 08-14-2010, 04:11 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Once you take the box off you will see why it is there. I don't mean to sound like a smart alack in my statement.
Jim
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
remove and re-use stone veneer Cecosugi Building & Construction 6 08-20-2009 11:08 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
Remove Joist Bridge?? busy1 Building & Construction 9 09-01-2008 10:56 PM
