Can I Cover Over My Existing Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-21-2013, 01:04 AM   #1
Can I cover over my existing roof?
Iím planning to replace my whole roof but someone suggested me to cover the existing roof with the new one Iím not sure that itís good for my home or not I f you guys have some knowledge about this specific issue kindly share it with me.
dereklawler is offline   Reply With Quote
Old 05-21-2013, 01:29 AM   #2
747
registered
747's Avatar
Rewards Points: 534
Yes you can layer over an existing roof. Check code. Most is usually 2 layers. However most guys don't like to do this for multiple reason. One they can't get a good look at the sheathing. Two they don't like the esthetics, A couple examples.
Finally if laying over existing shingles it will be more money to re-roof someday down the road.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
OldNBroken (05-21-2013)
Old 05-21-2013, 01:41 AM   #3
Doing This Way Too Long
Rewards Points: 532
...now cue the "you should never do recover" purists.
747 'bout summed it up for you. It is preferable to tear it off but you can recover it to whatever your local codes allow.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
oh'mike (05-21-2013)
Old 05-21-2013, 10:33 AM   #4
Roofmaster
Rewards Points: 2,172
Don't do it. There are many more reasons than those already mentioned, not to mention that a quality oriented steep roofer would not do it even if you asked him to.
Its got nothing to do with being a "Purist" Its got to do with doing things right.
Old 05-21-2013, 05:00 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
remember, just because you can do something doesn't mean you should ...... big difference
excellent advise given by others, they know of what they speak
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-21-2013, 06:48 PM   #6
Rewards Points: 12,794
I'll just refuse to do a roof over.
They look like poop, more often then not they never seal right.
I've gone to houses that had 4 layers of shingles on them.
They about had a heart attack when I told them what it was going to cost just to remove them.
Old 05-21-2013, 07:30 PM   #7
The big thing is it doesn't let the roof dry correctly, speeding up the brake down of the shingles. It can cut your roof life down 30%
I've done it 2 times ever out of thousands of roofs, and only under special circumstances. I give no warranty with it, and never recommend it.
jsbuilders is offline   Reply With Quote
Old 05-21-2013, 08:12 PM   #8
Davejss's Avatar
Rewards Points: 740
One layer shingle-overs are very commen in my area. If the existing shingles are in good shape, no leaks, no holes, not too curled, no lifting, etc., then a shinlge-over rather than a strip off is an econimical alternative to stripping and re- roofing. However, most of us prefer to strip for all of the reasons mentioned. The new roof lays down flat quicker, you can check for roof deck integrity, and you can better handle flashing around obstacles. It costs a bit more for labor and disposal, but you get a much better job.
Having said that, you can certainly do a good job of shingling over as long as attention is paid to the areas mentioned.
Davejss is offline   Reply With Quote
Old 05-21-2013, 09:09 PM   #9
Roofmaster
Hi Dave,
Good Post. Im sitting here laughing after reading: "If the existing shingles are in good shape, no leaks, no holes, not too curled, no lifting, etc."
Why the heck are they replacing it in the first place???
Old 05-22-2013, 05:10 AM   #10
Davejss's Avatar
Rewards Points: 740
Originally Posted by jagans View Post
Hi Dave,
Because it may need replacing. The granular material may have worn off, the shingles could be faded and unsightly, the shingles may be years past their design life span, there may be an addition which needs to match, etc.
The Following User Says Thank You to Davejss For This Useful Post:
OldNBroken (05-22-2013)
Old 05-22-2013, 05:15 PM   #11
Oso954's Avatar
Rewards Points: 402
It still comes down to pay now, or pay later.
Oso954 is online now   Reply With Quote
Old 05-22-2013, 10:09 PM   #12
Roofmaster
Granules worn off does not qualify as "Good Shape" to me, but whatever. We Beat this dead horse enough.
Old 05-22-2013, 10:11 PM   #13
GBrackins's Avatar
just for you J
Gary
Old 05-29-2013, 01:12 AM   #14
thanks to all of you
thanks to all of you guys for your valuable opinions it really a good Experience to be a part of your community. :-)
Flintlastic SA over existing torch down roof? aribert Roofing/Siding 2 05-16-2012 08:32 AM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Re shingle or over shingle ? MIKEY 43 Roofing/Siding 18 02-27-2012 09:26 PM
Cover roof to lower temperature? DiceyPropositions Roofing/Siding 8 05-20-2008 09:17 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
