Can I Caulk This Flashing - Pics Attached - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-18-2011, 05:09 PM   #16
Originally Posted by Tom Struble View Post
it probably been leaking since day one
Well then you have needed it replaced since day one and the current issue is irrelevant..
Omegaroofer is offline   Reply With Quote
Old 08-18-2011, 05:23 PM   #17
kwikfishron's Avatar
Rewards Points: 760
Iíd be up there with a hose. If the step flashing is there and in good shape and all there is to do is replace and install the counter properly then Iím not seeing $3,200. But I aint no roofer, what do I know.
Iím a little surprised by omegaís response suggesting more goop as the fix .
kwikfishron is online now   Reply With Quote
Old 08-18-2011, 05:31 PM   #18
Well you do have to consider that even with new metal it is going to have to be "gooped"... The problem in this situation is the mounting..
And I would guess that with that $3200 we are talking about more flashing than just these two areas.. Also wood shake roof it is probably steep, requiring setup. Also sheets of copper are expensive now days and if you want it done right grinding out that mortar takes time..
Old 08-18-2011, 07:49 PM   #19
Tom Struble's Avatar
Rewards Points: 2,002
exactly,so i guess your ''solution'' would be too
Tom Struble is offline   Reply With Quote
Old 08-18-2011, 07:56 PM   #20
If it all has failed then re-do it... Other then that bend and pin the metal back and caulk with Vulkum..
The Following User Says Thank You to Omegaroofer For This Useful Post:
Tom Struble (08-18-2011)
Old 08-19-2011, 12:27 AM   #21
Based on the picture, I would say that it will be better if you just spend money to have it inspected by a professional builders.
sassyconnie is offline   Reply With Quote
Old 08-19-2011, 08:56 AM   #22
AGWhitehouse's Avatar
Using a hose to find holes sounds like you'll cause more damage than you'll prevent. That crack in the brick coupled with the delaminated flashing is definately one source of water infiltration. Correctly installed step flashing requires no caulk...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Tom Struble (08-19-2011)
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Beefing up these columns (pics attached) joeyboy Building & Construction 9 06-25-2007 08:46 PM
I need to enclose my Loft. Looking for your opinion what I should do. Pics attached TheLoft Carpentry 3 04-23-2007 01:44 PM
Water lines on sloped ceiling (pics attached) Mr. Michael Roofing/Siding 8 03-27-2007 02:13 PM
Need help please asap...patching plaster pics attached mood Building & Construction 2 07-30-2005 10:06 PM
