Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-01-2010, 03:50 PM   #1
California Open Valley
Hello all, I'm looking for some direction on how to lay starter strip with a open California valley. I'm guessing I stop it and cut the angle of the first parellel shingle to the valley? I'm also wondering how to cut the top of the flashing at the saddle.
http://www.gaf.com/Documents/Califor...-43-791-v1.pdf
Thanks in advice for the responses.
Damien
DamienLong is offline   Reply With Quote
Old 11-02-2010, 05:56 AM   #2
Pro Slate Roofer
tinner666's Avatar
I haven't done that type of valley. Just make sure none of your shingles come to a point. The point will catch plenty of water and send it under the roof and into the house.
Frank
tinner666 is offline   Reply With Quote
Old 11-02-2010, 08:28 AM   #3
Residential Roofer
Slyfox's Avatar
Damien
Run your starter strip 'over the metal' to the angle cut, then the first course, etc.
At the top of the valley your metal will be cut roughly and inch or so above the top, than make a couple/a few release cuts to allow the metal to rap over.
Than run your ridge caps across it 'after shingling' making sure to keep your fasteners away from the valley's center line.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 11-02-2010, 12:23 PM   #4
Slyfox, thanks for the response. I'm guessing I have to cement the starter strip on the metal flashing to mimic the mastic on the parellel shingles?
Need input on this open valley technique jogr Roofing 12 11-01-2011 07:49 AM
open vs closed valley KarlJay Roofing 1 09-19-2010 07:58 AM
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 07:30 PM
Open valley flashing question steve1234 Roofing 2 10-01-2007 01:19 PM
Electrical service too near valley of roof? adamselene Roofing 3 05-11-2007 08:56 AM
