Cable Rafter Ties - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2014, 05:50 PM   #1
Rewards Points: 117
cable rafter ties
I've decided to add rafter ties to my home. Im thinking of using cable.
1952 house. This house was built with NO rafter ties and very few collar ties. The joists run from gable to gable. Ridge is not sagging, walls are not bowing. However, I have added hurricane straps and gable supports. Soon, i will be replacing the roof and while at it, screwing the roof planking to the rafters. Im making my home as hurricane resistant as possible.
Therefor I have also decided to add cable rafter ties and 2x6 collar ties.
I need advice.
pa
paulmars is offline   Reply With Quote
Old 05-14-2014, 06:23 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Why do you need both?
Sounds like well placed collar ties would do the trick of the house is not bowing as is.
The Following User Says Thank You to Windows on Wash For This Useful Post:
joecaption (05-14-2014)
rafter ties markharmon Building & Construction 2 05-09-2013 07:06 PM
Good Quality Cable Ties? smata67 Electrical 7 01-21-2012 07:57 AM
tension wire as rafter ties?? Wolfen Building & Construction 9 03-01-2011 11:21 AM
Plastic cable ties ODDJOB72655 Electrical 5 07-20-2010 05:07 AM
Garage Rafter Ties - Can I remove them? cmj Building & Construction 6 02-02-2010 10:57 AM
