Butterfly Roof Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Poll: How do I fix this gutter problem
Poll Options
Old 02-12-2014, 03:08 PM   #1
The ice build-up on the downspout of our butterfly roof gutter has pulled the guttering off our house. When ice in the valley of our butterfly roof melted it ran under the soffit and dripped inside the house - no matter how much we tried to calk or seal the roof. So, we put a coil-heater on the roof valley to keep ice from forming. Water then ran into the gutter and the leaking the house stopped! The temperature this winder has been so cold that the heated ice water freezes solid in the downspout. With the downspout clogged, the water ran over the top of the gutter forming an enormous ice cycle so heavy it pulled all the guttering down. Should we remove the guttering and let the run-off just hit the patio like a waterfall, or is there a better way to use a gutting system?
Swopewood is offline   Reply With Quote
Old 02-12-2014, 06:23 PM   #2
Rewards Points: 12,812
http://bct.eco.umass.edu/publication...ting-ice-dams/
Did you also add deicing cable inside the gutters and down spouts?
Old 02-12-2014, 06:27 PM   #3
Made any changes in the attic to prevent the ice in the first place?
Air sealing, adding insulation, making sure there the correct amount of venting?
Added heat tapes inside the gutters and down spouts?
Windows on Wash (02-13-2014)
Old 02-12-2014, 07:09 PM   #4
Rewards Points: 406
In retrospect, when the heat cable is run through a hole you should have drilled in the gutter with a drip loop return, the water drips to the ground and freezes where the ice can be dealt with rather than filling the gutter.
Old 02-12-2014, 07:55 PM   #5
PS using the poll function is useless.
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 10:44 PM
Removal of gutters for new roof Greg714 Roofing/Siding 3 05-25-2012 08:20 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
roof leaking behind gutters bigg_red1 Roofing/Siding 19 04-20-2011 06:06 PM
