Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-04-2012, 08:45 PM   #1
Bulge in roof shingles and valley flashing
I just noticed while checking up on my one story roof that one area where shingles meet valley flashing, the flashing and shingles have a small spot that bulges. If I step on top of it, it flattens out (with a pop kind of sound) then will bulge back up when I walk away. This is repeatable.
Is this:
bad roofing job that led to this?
eventual wear and tear of roof?
an indication of a roof problem that needs to be fixed? immediately or can be deferred?
It's only one small area of roof though.
daluu is offline   Reply With Quote
Old 08-04-2012, 09:09 PM   #2
Without a picture were all going to have to just guess.
Can be a whole lot of things.
Some simple things it could be is they used aluminum flashing under the valley
and it's just buckling a little,
Shingles nailed to close together.
Tar paper was not layed flat.
Only to find out is to remove a few shingles with a flat bar and cheak it out.
Old 08-07-2012, 01:53 AM   #3
Roofing Contractor
The bulge in the valley could be valley not nailed properly. The bulge in the shingles may be on the eave were the ice and water shield has bubbled???
dougger222 is offline   Reply With Quote
Old 08-07-2012, 12:59 PM   #4
STAFF
BigJim's Avatar
Could be ends of decking not nailed properly.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Windows on Wash (08-08-2012)
Old 08-07-2012, 01:51 PM   #5
Thanks for replies, helpful info to know. I'll post a pic for reference in a few days.
Roofing Material History Roofmaster417 Roofing 4 09-08-2011 05:49 PM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
1000 bucks to fix the valley on my roof, is this ok? astronomer25 Roofing 3 09-14-2008 08:36 PM
Do I need flashing in the valley for woven shingles? tidal9 Roofing 3 06-06-2008 12:15 PM
Open valley flashing question steve1234 Roofing 2 10-01-2007 01:19 PM
