Building Deck On New Tpo Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-07-2011, 06:39 AM   #1
building deck on new tpo roof.
I am currently renovating an old house in Richmond, Va, and I have a question about TPO roofs. The home inspector swore that the existing roof was in good condition, however I found out later that this was not the case.
I had a brand new TPO roof installed and also a decent sized roof access built. The main section of the roof has a very low pitch and I want to build a small deck directly on top of the tpo. Are there any precautions I should take to protect the tpo?
Also I am planning on building a barrier fence to keep people away from the roof edge and I will need to penetrate the TPO on the parapet walls ( the house is a brick row house) to secure the barrier fence. What will I need to do to flash in these penetrations, I was thinking about using some silicone, but I want to do it right, so if I need to I will call the roofer back out.
Thanks,
Lawrence
lkheisler86 is offline   Reply With Quote
Old 11-07-2011, 07:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Paging Tinner
Old 11-07-2011, 08:42 AM   #3
Please elaborate. I do not follow.
Old 11-07-2011, 08:52 AM   #4
roof or stucco first
tiner666 is out of richmond
Old 11-08-2011, 09:45 AM   #5
Call the roofer back, or give tinner a call. You should have this done by a proffesional and done right the first time. Quality TPO is a Cadillac. You donít want patch a Cadillac with kia parts.
Roofster is offline   Reply With Quote
Old 11-08-2011, 09:51 AM   #6
The deck will be laying on top of the new tpo, not anchored in, the only intentional tpo penetrations will be on the parapet wall. I guess my question should be restructured. What should I do to protect the new tpo under the floating deck?
Another Deck Question...Gable Roof Post Placement Issues. mgh-pa Building & Construction 2 06-02-2011 06:26 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
