Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-17-2010, 06:40 PM   #1
Building Chase Around a Brick Chimney
I want to build a wood and vinyl sided Chase around my present brick chimney.
The chimney (at the roofline) is 26” w, 33” long, and 46” & 36” high. When it rains hard or for long period, the brick absorbs the water and then leaks down into the house. I do not want to put on a sealer; I have already tried that without success, i.e. still leaks.
Do you have any experience doing something like this?
TDFICH is offline   Reply With Quote
Old 05-17-2010, 06:58 PM   #2
Commercial Roofing
AaronB's Avatar
Nope. Are you sure it wouldn't be more cost effective to just rebuild the chimney?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-17-2010, 07:50 PM   #3
Shut in w/o Home
seeyou's Avatar
It's likely leaking at the crown. A full chimney cover might possibly solve this. Got any pictures and are you sure it's a "chimney"and not a brick veneered chase?
Where is it located on the roof? At the eave, in the middle of a roof plane, at the ridge.
seeyou is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 07:51 PM
Any good brick chimney water repellents? quigleybmd Roofing 3 04-12-2010 07:19 PM
Sealing chimney chase(?) cbrc5eric Building & Construction 3 03-15-2010 10:31 AM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
