Building A 12x10' Shed Roofed Outbuilding - Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-02-2010, 12:58 AM   #1
DIYer
Rewards Points: 93
Building a 12x10' shed roofed outbuilding - questions
After the rainy season, I'm planning to construct a 12x10' outbuilding with a simple shed roof (5:12). Id like to make the building inhabitable so it will be insulated and finished.
I'm contemplating ventilation...I should ventilate, right? If so, with an eave soffit, how should the air be vented at the ridge? I found an image from Cor-A-Vent that's a possibility:
I'd like to also make this a "green roof" with soil and plants on top. I'm thinking 2x8 douglas fir no.2 rafters at 24"oc should be sufficient, no? Looking at a span table, they're good to 11'8" with 20psf dead load
Thanks in advance for your advice
dwoloz is offline   Reply With Quote
Old 10-02-2010, 04:45 PM   #2
DIYer
Rewards Points: 93
Another question:
I'd like a healthy overhang, maybe 2' or so, on the 12' side with the front door and am wondering whether I can cantilever it or if I need a support post.
Old 10-02-2010, 06:41 PM   #3
jlhaslip's Avatar
Rewards Points: 390
2 x 8 might be too light depending on the amount of soil on the roof. 20 psf isn't a whole lot.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-02-2010, 08:16 PM   #4
DIYer
Rewards Points: 93
Hm, I think you're right
Green roofs have a lot of factors like soil media, depth, plants, etc. I'm thinking I will go lightweight with 4" of expanded clay soil media, sedum succulents and some kind of lightweight drainage substrate. The most weight it will see is in a rain with all the material wet
This pdf gives a green roof example of 20psf dead and 30psf live
http://docs.google.com/viewer?url=ht...l%20Design.pdf
This one gives the example of a 26psf dead load in addition to the load of the roof
http://docs.google.com/viewer?url=ht...en%20Roofs.pdf
This one says 15-50 additional dead load for a green roof
http://www.glwi.uwm.edu/research/gen...oofinstall.php
So perhaps 30psf is a more reasonable estimate (if using materials on the lighter side).
This calculator unfortunately only goes to 20psf http://www.awc.org/calculators/span/...rcalcstyle.asp but 2x10s seem safe
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Deck Building Project Pictures (and Some Questions) Ler0y Jenkins General DIY Discussions 52 03-06-2009 12:33 AM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
Building a Deck - Questions about pouring the footers Ler0y Jenkins General DIY Discussions 5 06-03-2008 08:42 AM
