Buckling Shingeles(NEW ROOF) - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-10-2009, 07:51 PM   #1
buckling shingeles(NEW ROOF)
I have 30 yr tamco heritage black walnut one year old roof. I watched the installation it seemed flawless. The shingles are buldging up as if there were expansion problems. I had another pro roofer look at it He does not know the problem. The buldging is even lifting the ice shield. Can anybody help.
kevinl10 is offline   Reply With Quote
Old 10-11-2009, 11:47 AM   #2
Commercial Roofing
AaronB's Avatar
Did you check the roof deck?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-11-2009, 01:57 PM   #3
Household Handyman
Rewards Points: 1,408
AaronB has a good point. You stated that the "ice shield" is even buldging up, so you must live in a cold climate. I'm wondering if the newer shingles may be building up and holding in heat you did not have a prolem with previously. You may have been border-line with this previously and it did not show up. I would have to do as AaronB suggested and look into the roof decking/sheathing to see if this has risen up for some reason. IF you have an attic or any accessable space to view the inside/bottom of your roof decking, you may be able to see if there is any separtion of the decking from the rafters, or even serious buckling between the rafters. Good Luck, David
Old 10-11-2009, 09:46 PM   #4
New roof buckling
The house is new construction. The attic doesn't even have insul. In fact I was going to use spray foam but called the shingle manufacture they said it would over heat so I did not use it. The roof dck is well vented and it was not raining when installed. It is occuring in many dif. loc. I have NY climate(long island). I have baffles were needed and a ridge vent all around. I had a pro roofer look at it he said call the manuf. it could be a defect. I should note they discontinued black walnut
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
