Bubbles In New TPO Roof A Problem? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-16-2011, 08:43 AM   #1
Bubbles in new TPO roof a problem?
I have a new TPO (Firestone) membrane on my roof. The seams are fine, but I have numerous bubbles, where apparently the glue did not stick. Perhaps it was too cold that day. It's obviously not a problem now, but will it be in the future? Since the roofer hasn't yet installed flashing at the ends of the roof, he hasn't asked for full payment yet.
dwyanehicks is offline   Reply With Quote
Old 02-16-2011, 12:56 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Maybe not. Sometimes bubbles occur if the glue hasn't dried completely (during cooler weather), but will disappear as the glue dries. Give it a few days.
seeyou is offline   Reply With Quote
Old 02-18-2011, 03:15 PM   #3
Low Slope Roofing
Rewards Points: 114
generally not going to be a problem. Is it a big area? If it was cold and the roofer didnt let the glue flash off properly that causes it, using too much glue will cause it too.
1985gt is offline   Reply With Quote
Old 02-18-2011, 06:16 PM   #4
Re: bubbles with TPO
Thanks for the replies. I didn't want to rely solely on what my installer said, which was that he thought it might flatten out with hot weather and that it wasn't a serious problem. It's 2000 sq. ft., mostly stuck down; so, it's not going to blow off. I suppose it's just a little annoying.
Old 02-18-2011, 06:19 PM   #5
Low Slope Roofing
Rewards Points: 114
If your not happy your roofer should fix it. With in reason. Like I said if they are just some small 6" or so round bubble I wouldnt worry about it. If you like snap some pics and post them up.
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Roof pitch problem AnySeason Building & Construction 4 05-09-2009 07:40 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
old roof problem griffithj Roofing/Siding 1 07-16-2006 03:00 PM
