Broken Rotary Wind Turbine-Fix It Or Replacement? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-11-2009, 07:21 PM   #1
Question
Broken Rotary Wind Turbine-Fix it or replacement?
Hi everyone! I'm new here, but joined to see if anyone here could help me.
I had a wind turbine that got damaged by a hurricane. The whirly part blew off. The rest of the casing seems fine. However, if we get a decent wind, the spinning part falls off again.
I was wondering if they sell a part that may hold that on again(a bolt or screw?) or if I have to replace the whole turbine housing and all?
Also, if replacement of the assembly is the best option, is there risk of damaging my roof shingles and causing a leak?
Any advice or help that anyone has would be appreciated!!!
Thanks in advance!
bobrummel is offline   Reply With Quote
Old 02-12-2009, 07:02 AM   #2
If it is not a true "Whirley Bird", I would replace it with one. If it is, contact them, they have the parts to fix it.
Old 02-16-2009, 07:02 PM   #3
Where in the world is "Whirley Bird"
Where would I be able to purchase a true "Whirley Bird" vent?
Old 02-17-2009, 10:49 PM   #4
The item will be cheaper to replace rather than to hunt down parts and try to repair a broken used one.
Replace it.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-18-2009, 08:09 AM   #5
Installation instructions
Do replacement instructions come in every box, or can I find them online somewhere?
Are there other threads here regarding the best ones?
