Broken Roof Joist - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 01:05 PM   #1
Broken roof joist
I took down the drywall in my upstairs bathroom which is connected to the area above my kitchen. (So looking through the wall I can see the area above the kitchen ceiling between the a roof.) I have attached a photo.
I noticed one of the 6" roof joists is broken.
While I have the access I would like to repair it.
I'd assume I can sister it up with a 6" piece of lumber but wanted to know:
1) Should I press the broken piece back into its proper position and then attach a second piece of wood, or leave the broken piece in its same position and attach the new piece?
2) What type of screws should I use?
3) How long past the damaged area should the new wood go?
Any other tips?
Thanks.
Velvis is offline   Reply With Quote
Old 07-16-2012, 01:13 PM   #2
Rewards Points: 14,306
Just a couple of guesses being made from that one picture.
Looks like 24" or more spacing on those rafters.
It also looks like there was a roof leak there at some point, has this been fixed?
With spacing like that I'd guess the roof used to or still does have metal roofing.
Yes a patch will work but it needs to be as long as you can possibly fit up into the attic to spread out the load. It also needs a sistered joist on both sides, not just one.
I'd use construton adhevive and 3" ceramic coated decking screws.
Old 07-16-2012, 01:17 PM   #3
Yes the roof was redone recently.
It's not a metal roof, but rather a very old house.
I didn't think of attaching on both sides, thank you.
Should I place the original beam back in its proper position before attaching the new wood?
Old 07-16-2012, 01:21 PM   #4
I would screw one end in tight to the sheathing below the crack, then use the new piece as a lever to lift it back in place then screw in the other side.
May take two people, one to lift and one to do the screwing.
New shingles, roof slats are now broken... dzl13 Roofing/Siding 2 08-24-2011 04:53 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
