Brand New Roof Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-23-2014, 08:17 PM   #46
Roofmaster
Rewards Points: 2,210
Originally Posted by ParagonEx View Post
I looked at more than a dozen houses last week in Milwaukee from 60-100 years old with ice dams.
I don't disagree that the interior heat plays a part but if you can honestly say weather doesn't play a part in it I can't seriously have this conversation.
Oh I'm sure that weather plays a major role. Just for curiosities sake, do you have any feel for how many of those older homes had their attics retrofitted into living space? Changing use has a lot to do with developing problems where none formerly existed. Interesting......
Old 02-23-2014, 10:43 PM   #47
Rewards Points: 214
Originally Posted by jagans View Post
Im sure you know how an ice dams form. They form when interior heat is lost into the attic and hits the underside of the roof deck, causing melt water to run down toward the eaves where it hits the cold area above the soffit and freezes. As long as the temperature below the deck is kept at the same temperature throughout you will not get an ice dam
Not a cut & dry true statement. You can have 4 feet of properly installed insulation in your attic and a jet engine providing ventilation and ice dammits can still form.
If the conditions are right, meaning the orientation of your home and solar heat gain from the sun, ice dams can still form no matter how well insulated and ventilated your attic is. If the temperature and sunlight conditions are right, the snow is going to melt, and re-freeze on metal gutters.
rosem637 is offline   Reply With Quote
Old 02-24-2014, 06:45 AM   #48
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
+1 rosem637.
This was discussed earlier. Jagans knows this and he was probably referring to what is the responsible cause of 95% of the ice dams in this case. Poor insulation, unchecked air flow from the living space, and inadequate ventilation.
The Following User Says Thank You to Windows on Wash For This Useful Post:
jagans (02-24-2014)
Old 02-24-2014, 09:00 AM   #49
Roofmaster
Agree, and it does not help when you design a home with four gables running to a central point with no way to get any appreciable convection going. We used to take a piece of paper and crumble it into a tight ball then open it up a bit then say "This is a roof designed by an Architect" We then took a piece of paper, neatly folded it down the middle of the 8.5 dimension, opened it to 45 degrees, and said "This is a roof designed by a roofer" LOLOLOL
Old 02-24-2014, 11:36 AM   #50
Rewards Points: 285
My father just put me in contact with a roofer he's known since childhood who said they should have never installed the roof in winter (i'm in NJ where we're having an awful winter).
Reason being is because the air temp isnt high enough for the seal-sealant on the shingles to properly adhere. The only alternative would have been to caulk every row of shingles but that is very expensive.
He suggested I get a roofing consultant to do an inspection of the roof and give me a written report. He also said if the company didnt caulk every row which he doubts since it's so expensive, his personal recommendation would be to redo the entire roof in the spring.
So does this sound right?
marcus118 is offline   Reply With Quote
Old 02-24-2014, 02:51 PM   #51
Rewards Points: 656
Its not too uncommon to shingle in the winter, if its not too dusty where you are the shingles should seal fine come spring. Hand tabbing is recommended(using roof cement, not caulking), but I've never done it and rarely have issues.
The winter install has nothing to do with the issues your having.
PatChap is offline   Reply With Quote
Old 02-24-2014, 03:23 PM   #52
Winter Install
Yeah, as some have said, the winter doesn't matter. The roofing system will protect the roof if installed properly. Once the spring and summer comes, it will just add that much more protection to the roof when it seals up.
TedLeger is offline   Reply With Quote
Old 02-24-2014, 03:24 PM   #53
+1
The lack of sealing between the shingles has nothing to do with the ice damming issue. The shingles, once then get some heat in them and if they aren't fouled with dirt between the courses, will seal down fine.
The issue is what has been discussed previously. Gutter routing, lack of ice/water, not removing the siding, and poor flashing.
Why Leaking Roof under Dormer / hole in OSB!!! MB1 Roofing/Siding 32 12-15-2011 04:20 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 03:50 PM
Supposedly 'new' roof is leaking beejay Roofing/Siding 3 03-06-2007 10:55 AM
