Box/Yankee Gutter Repair, What Is This Vent? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-28-2010, 07:52 PM   #1
Box/Yankee Gutter Repair, What is this Vent?
I have been looking into getting my box/yankee gutter repaired. I was trying to figure out why the previous owners put some type of vent directly above it the gutter? (not sure what the proper term of the item is but would be interested to know so I can do some more research) Is this used to prevent moisture from forming in the attic space? (The attic is livable space) I had someone tell me it was a cap preventing water from going to the downspouts but it seems peculiar that someone would put this on the roof for no reason. I'm wondering if there was a moisture issue or ice dams forming. I've owned the house for about a year so I'm still discovering all the surprises. Appreciate all the help.
Box/Yankee Gutter Repair, What is this Vent?-roof2_resized_small.jpg
psg980 is offline   Reply With Quote
Old 09-28-2010, 08:22 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The cap indicates it's a vent for a gas furnace.
It could even be a plumbing vent. Either way, it's in the wrong place. It should have been ell'd to come out in the shingle roof at least 2' above the gutter.
tinner666 is offline   Reply With Quote
Old 09-30-2010, 05:49 PM   #3
It does seem odd if it is a plumbing/gas vent. Directly underneath the pipe is a downspout so I'm curious if the pipe comes out inside the box gutter then comes up. I suppose the only way to find out is look inside the box, will get the roofers to look at it.
Old 09-30-2010, 06:36 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
radon possibly?,the downspout you see directly below may be covering the rest of the pipe
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
seeyou (10-01-2010)
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 06:40 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Tin roof box gutter repair mcampise Roofing/Siding 10 09-13-2007 04:16 PM
