Box In Eaves Or Repaint? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-20-2012, 11:19 PM   #16
Only because I have already ripped these to size, I am not completely set as I dont really how to attach the osb
Would I build some sort of framing or something?
jamminjohn is offline   Reply With Quote
Old 04-23-2012, 11:45 AM   #17
Just a DIY guy
I'm not 100 percent certain, but I think you need a J frame on either side to hold it in place, and I'm guessing you could mount that to (1) the fascia board on the end of the rafter, and (2) along the side of the house attached to each rafter. If you need to position the J channel along the house at a lower level, you could simply screw a length of wood of appropriate dimensions to the rafters (perpendicular to rafters), which will give you a continuous surface for the J channel.
http://www.youtube.com/watch?v=Ez2-C...eature=related
M3 Pete is offline   Reply With Quote
Scabbing on Eaves? JeepNick Building & Construction 6 02-27-2012 09:21 PM
Open Eaves Soffit and new blown insulation mpierce9 Roofing/Siding 10 05-14-2011 08:51 AM
Caulk under eaves or not tns1 Roofing/Siding 1 11-05-2010 03:41 PM
Will boxing-in roof eaves exacerbate mold growth? pnlop1 Roofing/Siding 3 12-25-2009 07:08 AM
Building overhang eaves and soffits on old house justdon Remodeling 6 07-04-2008 09:59 AM
