Boarded Over Soffit Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-13-2010, 09:26 PM   #1
Rewards Points: 286
Boarded over soffit vents
I visited my brother-in-law this past weekend. This was the first time we saw the house they bought 5 years or mor ago. The first thing I noticed was that the soffit vents were completely boarded over by the prior homeowner. I guess there was a problem with squirrels. The roof has a ridge vent and a fairly small gable vent on each end, slightly larger tan the other. My initial reaction was to tell them that this was not adaquate and that they should consider a power gable vent or reopening the soffit vents after consulting with a pro of course.
Further inspection of the attic revealed no evedence of problems. The soffit vent spacers are still there although leading to blocked vents. The attic floor is well insulated with a thick layer of loose OCF Pink. There is no evidence of moisture or mold problems. The shingles are at least 5-10 years old and show none of the telltale signs of cooking in the heat- no curled edges- generally in good shape. My brother-in-law lives in Massachussetts.
So, after causing them initial concerne, I told them in my non-expert opinion that it doesn't look as bad as it originally appeared but that they may still want to look at more ventilation. I know pictures speak volumes but I don't have any. I'm thinking at this point that if it ain't broke don't try to fix it and they should just leave it as is but I'm open to other opinions.
Jim F is offline   Reply With Quote
Old 04-13-2010, 10:20 PM   #2
Commercial Roofing
AaronB's Avatar
How big are the gable vents? I like gable vents over can or ridge vents cuz a slight breeze can turn the air in the attic over quite quickly. You gotta have sufficient gable venting, though.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-13-2010, 10:24 PM   #3
My house (Cape) did not have any soffit vents either when I moved in
Roof is approx 10-15 years old now & in great shape
"2nd floor" was finished without any vent between insulation & roof deck
Gable vents did very little, no ridge vent
I'm adding soffit vents, added a ridge vent
Is the roof shaded ? That can make a big difference
Old 04-15-2010, 05:52 PM   #4
Rewards Points: 286
Thanks for the replies. I'm thinking either just leave it alone or monitoring the summertime temp.
Old 04-21-2010, 02:39 PM   #5
Scuba... We recently introduced a new product for introducing adequate intake ventilation on tough-to-vent properties. It's called Cobra FasciaFlow intake vent. It combines the form of a fascia board with the function of an intake vent. For more information, if you're interested, please visit http://www.gaf.com/Roofing/Residenti...aFlow-Vent.asp
Thanks and best of luck with your project!
GAF Materials is offline   Reply With Quote
Old 04-21-2010, 05:10 PM   #6
Thanks - interesting product
I'm actually adding vinyl soffit vents, still have a few areas left to do
But all the fascia boards are all installed already
Old 04-21-2010, 10:10 PM   #7
Registered User
Rewards Points: 526
Hello........
At least now I can update this, thanks to that advertisement...... http://www.cor-a-vent.com/PDF/S4002P.pdf
Be safe, Gary
Soffit vents on older houses with "curved" ceilings Labman101 Roofing/Siding 2 02-07-2010 10:33 PM
No soffit or gable vents wooody Roofing/Siding 8 08-19-2009 08:06 AM
Soffit vents installed? dkat Roofing/Siding 7 07-25-2008 10:45 AM
Soffit Vents Sammy Building & Construction 9 07-07-2008 06:31 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
