To Block Or Not Block - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 04:18 PM   #1
to block or not block
I have a vaulted roof over my deck. The rafters are 2X10. I have ran baffles between each rafter for air circulation. I ran the baffles into the sofit area to get air. Now I am going to put r-28 insulation and vapor barrier. My question is should i block between the rafters and cut a notch out for the baffleor leave the rafters open where they meet the top plate. my thinking is that air will go up the whole area instead of just up the baffles and condensation will collect on the vapor barrier. but i am not sure. each rafter length is 18 feet and the rafters are on 16" centers. So if someone can tell me if i should block the ends with a notch for the baffle or leave it open i would be grateful
brutherb is offline   Reply With Quote
Old 09-09-2010, 04:25 PM   #2
Doing This Way Too Long
Rewards Points: 532
Why notch them? Why not just use 2x8 for blocking
OldNBroken is offline   Reply With Quote
Old 09-09-2010, 04:45 PM   #3
so you are saying though that you do need to block the ends
Old 09-09-2010, 05:09 PM   #4
I put blocking between the rafters
With 2x12 rafters I used leftover scrap to cut to fit under the rafter vents
Old 09-09-2010, 05:15 PM   #5
thanks that was the answer i was looking for, i had a few poeople tell me to not block it and i could see how that was right.
Old 09-10-2010, 08:08 PM   #6
jlhaslip's Avatar
Rewards Points: 2,146
if you do not block the ends, the batts of insulation could migrate into the soffit space
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-10-2010, 09:38 PM   #7
Registered User
Rewards Points: 5,514
Pages 5 and 6, especially if in a seismic zone:
http://www.buildingsmartalliance.org...pter6final.pdf
The blocking prevents rotation of the rafters when under loads, and it stops outside air from wind-washing the insulation, pp. 12: http://www.nybtg.com/downloads/therm..._checklist.pdf
Don’t use cardboard baffles as pictured as they will get wet and mold. If no blocking is required by local Inspector, use foam board baffles to stop wind-washing or purchase these: http://www.adoproducts.com/wind.html to go with these: http://www.adoproducts.com/duro.html
Or for the same cost, just get these instead at HD: http://www.bergerbuildingproducts.co...sAccuvent.html
It’s all-in-one and self-extinguishing in a fire unlike the toxic foam ones.
Leave a 1” gap between baffle ends as per manuf.
Is this an outdoor deck? Heated? Why a vapor barrier? Location?
Gary
Old 09-11-2010, 01:26 PM   #8
thanks for the replies i installed the foam baffles and some of the insulation and blocks on the top plates. I have another question on venting. Since between each rafter is it's own void, each void needs to be vented. so that is a lot of vents. I can drill upwards under the drip edge as I have a metal roof that is baffled so there is an air gap under the drip edge. I would prefer to drill sideways and vent into the sofit. I have a 2X10 rafters so 8.5 inches deep, 16 inch centers, at a length of 16 ft for each void. would a 1.5 hole drilled through the side of each rafter venting into the soffit at each end suffice as adequate venting.
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 05:27 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 12:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
