Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-21-2007, 08:33 AM   #1
Bitumen cracking ?
One more question for y'all--
I've decided to have a bitumen (torch down) roof installed over the two porches.
I need to level the house (pier and beam) at some point, but $$$ . I must fix the roof leaks immediatly however.
Question-- Once the new roofing is in place, will leveling the house (6in or so upward on that part) cause the new bitumen surfaces to crack ? If not, how long a time to I have to safely level the house w/o damaging the roofing ?
As always-- thanks !!
Piney is offline   Reply With Quote
Old 03-21-2007, 09:17 AM   #2
Commercial Roofing
AaronB's Avatar
Bitumen cracking ?
Will probably damage the new roofing. Modified bitumen is generally an easy repair for an experienced torch roofer.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
EPDM vs Modified Bitumen for flat roof arubatan Roofing 16 11-19-2008 07:50 AM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
Tar & Gravel vs. Modified Bitumen ($13k or $7k) ?? Roscoe Roofing 6 10-10-2006 09:34 AM
How to keep caulking from cracking? MWM Painting 10 04-17-2005 06:59 PM
