Birdsmouth And Wall Sheathing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2013, 11:46 PM   #1
birdsmouth and wall sheathing
Hi all,
Im building a 10x14 shed. I want to frame everything and then sheath. Will that work? Do i need to have tje wall sheathing go into the birdsmouth or can i put the rafters up then just butt the sheathing to the bottom of the rafters?
tthanks!
lpv77 is offline   Reply With Quote
Old 06-30-2013, 08:04 AM   #2
Rewards Points: 13,300
You can just butt up to the bottom of the rafters.
If you look around at some of the older post you'll see where lots of people are complaining about there shed or garage being to hot.
By adding soffit vents and a ridge vent while your in the building stage you'll save a lot reconstruction.
Old 06-30-2013, 09:20 AM   #3
General Contractor
CENTERLINE MV's Avatar
I like to sheath walls before installing rafters in order to lock the structure plumb, straight, and square. Just make birds mouth 1/2" deeper.
CENTERLINE MV is offline   Reply With Quote
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
MTN REMODEL LLC (07-01-2013)
Old 06-30-2013, 09:28 AM   #4
Rewards Points: 528
Originally Posted by lpv77 View Post
Hi all,
tthanks!
No need for a birdsmouth on rafters for a shed. Just make the rafers put them up and put a 2x4 across the top of the wall nailing into the sides of the rafter and nailing into the top plate.
Second, I would not build a shed and try to build it all first without plywood on the walls first. As the poster above states, it locks the wall into plum.
framer52 is offline   Reply With Quote
Old 07-01-2013, 09:23 AM   #5
Thanks guys,
I actually re did my rafters to allow room for sheathing. I was going to just butt to the bottom, but I realized the sheathing wouldnt fasten to the top plate. The couple of rafters I installed im just going to trim with a sawsall to fit sheathing.
Old 07-01-2013, 11:22 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,640
Ditto^^^^^^^
Assuming wall is not too big to handle.... I like to apply sheathing while it's still laid down.
Best
MTN REMODEL LLC is online now   Reply With Quote
Wall Sheathing dclay79 Building & Construction 9 11-24-2012 11:54 PM
Determining pitch and birdsmouth cuts ktee Carpentry 9 09-01-2011 12:13 PM
Hip, common rafter birdsmouth depth? johnd393 Building & Construction 25 04-28-2010 10:04 AM
rafter birdsmouth and wall sheathing ??? Clutchcargo Building & Construction 4 07-10-2009 09:47 PM
