Which Is The Better Temporary Fix? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-20-2012, 07:08 PM   #1
Rewards Points: 243
Which is the better temporary fix?
The shingles and the metal drip edge on my second story roof are flush resulting in about an 1/8 inch overhanging the gutter. So quite a bit of rainwater is flowing behind the gutters and falling down right next to the house, washing out a flower bed and making a mess. I had two people out to look at it: one suggested running a strip of starter shingles under the existing shingles which he said would give about 7/8" overhang, the other suggested running a strip of aluminum under the existing drip edge and bending it down toward the gutter. Both estimates were about $300, so which would be the better choice? Both men agreed that the existing roof is very poorly done, and one noticed some rot along the eve due to the flashing not completely covering the wood.
chemman is offline   Reply With Quote
Old 10-20-2012, 07:25 PM   #2
Rewards Points: 13,274
If the roof is truly that bad then the best "fix" is to replace the room before more issues come up and it ends up cosing more.
I highly doubt there suggesting adding a a better drip cap under the old one. Far more likly it's going to be over the old one and further up under the shingles and longer so the water runs into the gutters.
I've had to do this before for someone that just could not afford to do it right and it worked ok.
Old 10-21-2012, 10:50 AM   #3
Rewards Points: 83
I've slipped metal under the starter course to extend the overhang. As joecaption said, not the preferred method but it worked.
bcdemon is offline   Reply With Quote
Temporary columns for a not-so-temporary fix? DoctorWho Building & Construction 19 06-14-2012 09:44 AM
If vinyl planks are a temporary flooring how temporary? mommiemara Flooring 0 09-14-2011 11:14 AM
Help with Temporary Support Needed DIYerIT Carpentry 3 05-12-2011 02:46 PM
Temporary support ideas for temporary beams? WillK Building & Construction 10 03-18-2011 09:37 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
