Which Is Better, .... Rubber Or Shingle For Semi-Flat Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-21-2010, 09:57 AM   #1
Which is better, .... Rubber or Shingle for Semi-Flat Roof?
Hi:
The Roof of my Family room is semi-flat roof and this morning we, the family found several small leaks streaming down from the the ceiling, due to past week's historic and rare massive snow storm, close to 3 feet.
We are aware of a price of Rubber is higher than Shingle, however because of semi-flat roof, I started to consider whether Rubber-Roof is more suitabable to the Semi-Roof?
One of neighbors told me, however that Rubber-roof has 'condension issue' that concerns me a great deal. In my guess, there is some moisture built-up between Rubber and insulation?
Your imputs would be truely appreciated.
Thanks,
cosmos10 is offline   Reply With Quote
Old 02-21-2010, 10:05 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
EPDM rubber would be the way to go. I prefer ISO insulation and it can be fully adhered or loose-laid over that. I guess, but don't know that felt could be laid under the insulation to prevent house moisture from causing those problems.
tinner666 is offline   Reply With Quote
Rubber Roof over Ice & Water Shield PerpetuallyRepairing Roofing/Siding 23 01-08-2009 11:50 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
