Best Way To Ventilate A 1200sf Ranch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 05:19 PM   #1
Best way to ventilate a 1200sf Ranch
I have a 1961 walk out Ranch located in Omaha, Ne. It has half vaulted ceiling and half attic. I'm getting details finalized to have my 19yr old roof replaced. I'm torn between adding a couple more static vents and two Aura vents or use continuous ridge vents? The ridge vent is 75ft total and cost around 1100.00 extra. They are using Lomanco OR-20 ridge vent as the product of choice. I helped my next door neighbor re-roof his house a few years ago and we put on a GAF system. It seems to be holding up fine. I'm worried about rain, snow and insects but most of all, proper installation. My house has 3.5" wide non-removable continuous soffit vents on 3ft overhangs. I had blow in insulation put in several years back and they used C baffles along the rafters down to the soffit. I suspect some insulation may have made it's way onto the vents over time so I'm going to go up on the roof and use my Toro blower vac and make sure they are clean. It's 20 ft up on the back side.
http://www.flickr.com/photos/81471303@N04/
mihulka3 is offline   Reply With Quote
Old 06-29-2012, 08:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 936
Make sure the soffits and go with the continuous ridge vent.
If you are worried about snow and rain, make sure that you have a baffled system.
That all being said, there is not nearly enough insulation in those rafter bays or that ceiling assembly.
If you are thinking about it, you could convert it to a sealed system with rigid foam and other stuff. It won't be cheap but it would work really well if done properly.
Old 06-29-2012, 09:23 AM   #3
Ridge Vent
Thanks for the assistance.
Old 06-29-2012, 08:00 PM   #4
Rewards Points: 850
$1100.00 for 75 feet of ridge vent. i think its only about a couple bucks a foot and then you cut back a few inches on each side of the ridge, but $1100.00, you must of had a sign on your t-shirt that said = HEY IM RICH. say it cost $4.00 a foot = $300.00, another 1/2 hour to cut the top = $100.00. boy i could retire just putting ridge vent in.
hotrod351 is offline   Reply With Quote
Old 06-30-2012, 01:28 AM   #5
Registered User
Rewards Points: 4,944
"Lomanco OR-20 ridge vent" I looked at the product and was not impressed. The baffles are designed wrong, as least to me: last diagram; http://www.oikos.com/esb/30/atticvent.html
Little biased: http://files.buildsite.com/dbderived...rived20936.pdf
Ready, set, go.....
Gary
Old 06-30-2012, 11:57 PM   #6
ParagonEx's Avatar
Rewards Points: 150
$1100 seems fair to me. $6 a foot for ridge and cap at my cost. Paying an employee. Use of equipment. Paying the government. I see only a profit of $300-400 for the company and a legitimate company needs more than that a day to keep going.
ParagonEx is offline   Reply With Quote
Old 07-01-2012, 05:39 PM   #7
Rewards Points: 936
Why do you think you are supposed to be profitable...?
The Following User Says Thank You to Windows on Wash For This Useful Post:
ParagonEx (07-01-2012)
Old 07-01-2012, 09:39 PM   #8
ParagonEx's Avatar
Rewards Points: 150
Good point!
Ranch base moulding in place of reducer PaulSDC Flooring 4 06-29-2012 09:27 AM
Ranch road: How much (deep) road base? JaimeS Landscaping & Lawn Care 5 05-16-2010 10:56 AM
Adding a second story to my ranch jpmildge Building & Construction 18 12-11-2009 11:40 AM
Anyone have a sample materials price list for 4br ranch home a re-wire job? ehoez Electrical 4 09-24-2008 02:00 PM
general and approx costs of raising a ranch dieselcake Building & Construction 1 06-20-2008 12:18 PM
