Best Way To Seal New Chimney Through Metal Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-27-2010, 11:49 AM   #1
Newly Retired
tuchodi's Avatar
Best way to seal new Chimney through Metal Roofing
I am going to install another wood burning stove in the family room and before I start what would be the best way to seal the pipe going through the Metal Roofing. It is 32" wide Alum sheets on the roof. I have done chimney installs on shingled roof before but not sure how to get a good seal on the metal roof.
tuchodi is offline   Reply With Quote
Old 02-27-2010, 02:27 PM   #2
Flexible roofing boot with proper sealant. I take it this is in a spot where snow will not bother enough to need a cricket.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 02-27-2010, 02:37 PM   #3
Newly Retired
tuchodi's Avatar
I have not decided how far from the peak the Chimney will come out so I may need a snow shield. What brand of flex boot would you recommend and also what would be the best sealant?
Old 02-28-2010, 12:33 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Here are examples of various methods. I only use sealants/caulks to provide seperation between the sheets to disrupt capilary action.
I've seen those boots, but never found a use for them yet.
http://rcs.si-sv2628.com/show_album_...&file=4434&s=0
tinner666 is offline   Reply With Quote
Old 02-28-2010, 03:26 PM   #5
Hello,
Here is the most common boots used to flash pipes here in AK.
make sure that you get a hi-temp one. http://www.dlm.co.nz/dektite.html
Keith
roofboy is offline   Reply With Quote
Old 03-01-2010, 10:45 AM   #6
Newly Retired
tuchodi's Avatar
Thanks Keith.
I will have to find out who sells the Dektite in BC. They look like the best sealing products I have seen.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 10:49 AM
Insulation under Metal roofing. Danimaniac Roofing/Siding 1 05-06-2009 09:00 PM
Replacing a Brick Chimney GeauxCajuns82 Building & Construction 4 04-16-2009 08:20 PM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 10:59 PM
