Best Way To Repair Where DircTV Antenna Was - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-29-2013, 07:10 AM   #1
Best way to repair where DircTV antenna was
I'm selling my house and the DirecTV dish will be removed. It's held into place with several 1/2" lag bolts through the shingles into the sheathing. If I cannot locate extra shingles, how do I repair the 8 small holes?
Thanks!
Fred
Fruler is offline   Reply With Quote
Old 04-29-2013, 10:31 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Get different shingles to as close a match as possible.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
OldNBroken (04-29-2013)
Old 04-29-2013, 10:36 AM   #3
So, there's no GOOD way to patch without replacing the shingles?
Thanks!
Old 04-29-2013, 10:53 AM   #4
Pro Slate Roofer
tinner666's Avatar
Not that I'm aware of. Water will get around/through any caulk you can buy.
Old 04-29-2013, 03:50 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Thanks!
Negative just as the man says below.
+1
Seen and gotten far too many calls about caulk fixes that don't hold up when it comes to the big holes.
Nail pops are one thing but lag bolts leave a much bigger hole.
Old 04-29-2013, 05:41 PM   #6
Then shingles it is!
Old 04-29-2013, 06:34 PM   #7
Roofmaster
Rewards Points: 2,172
You can bib them. On a cold day, or early in the morning, slide a wonder bar under the tabs, and break the self seal. Under the tab set a cut piece of 30 lb felt in flashing cement. Put a dab of lashing cement on each corner of the tab and set it back in place. You could also use a piece of aluminum somewhat color matched to your shingles. Mismatched shingles would look worse than bibbing in my opinion.
The Following User Says Thank You to jagans For This Useful Post:
Thurman (05-02-2013)
FIOS internet, and TV antenna sharing same line av-geek Home Theater 2 07-15-2012 01:28 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
