-   -   Best way to repair where DircTV antenna was (http://www.diychatroom.com/f9/best-way-repair-where-dirctv-antenna-178336/)
Fruler 04-29-2013 07:10 AM
I'm selling my house and the DirecTV dish will be removed. It's held into place with several 1/2" lag bolts through the shingles into the sheathing. If I cannot locate extra shingles, how do I repair the 8 small holes?
Thanks!
Fred
tinner666 04-29-2013 10:31 AM
Get different shingles to as close a match as possible.
Fruler 04-29-2013 10:36 AM
So, there's no GOOD way to patch without replacing the shingles?
Thanks!
tinner666 04-29-2013 10:53 AM
Not that I'm aware of. Water will get around/through any caulk you can buy.
Windows on Wash 04-29-2013 03:50 PM
Thanks!
Negative just as the man says below.
+1
Seen and gotten far too many calls about caulk fixes that don't hold up when it comes to the big holes.
Nail pops are one thing but lag bolts leave a much bigger hole.
Fruler 04-29-2013 05:41 PM
Then shingles it is!
jagans 04-29-2013 06:34 PM
You can bib them. On a cold day, or early in the morning, slide a wonder bar under the tabs, and break the self seal. Under the tab set a cut piece of 30 lb felt in flashing cement. Put a dab of lashing cement on each corner of the tab and set it back in place. You could also use a piece of aluminum somewhat color matched to your shingles. Mismatched shingles would look worse than bibbing in my opinion.
