Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-12-2012, 02:45 AM   #1
Best way to remove slate roofing
What is the best way to remove slate on my roof? It is not those separate pieces of slate but it is sort of like those concrete ones. It also has pebbles on top of the slate. I was wondering about how clean I have to remove it and what is the best way to do it?
Thank you
kk1234 is offline   Reply With Quote
Old 03-12-2012, 05:49 PM   #2
Exterior Construction
Windows on Wash's Avatar
Pictures....would get you more replies and directed feedback.
Old 03-13-2012, 04:22 PM   #3
My roof is covered with snow at the moment so I've googled a roof similar to mine. My roof is sort of like the picture here:
there are like sand and pebbles.
I plan on doing this myself
Old 03-13-2012, 04:30 PM   #4
Not a DIY job at all.
Your not going to have the equipmet, or the know how on that trype roof.
Old 03-13-2012, 04:31 PM   #5
That looks like a felt roof to me.
stuart45 is offline   Reply With Quote
Old 03-13-2012, 04:43 PM   #6
Doing This Way Too Long
So you have a tar and gravel built-up roof. (BUR) The gravel is just there to protect the actual roof from the environment. You confused me saying a slate roof.
Gotta agree with the others, yours is not very DIY friendly. What did you plan on replacing it with?
OldNBroken is offline   Reply With Quote
Old 03-14-2012, 08:58 AM   #7
+1
Not your average DIY project but can be done. I would suggest that you work with a roofer on this project though.
Old 03-14-2012, 01:33 PM   #8
Shut in w/o Home
seeyou's Avatar
Especially if they're so uninformed they're using "slate" to refer to BUR.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
OldNBroken (03-14-2012)
Old 03-15-2012, 02:13 AM   #9
i'm going to replace it with a torch on
Old 03-15-2012, 06:53 AM   #10
Shut in w/o Home
seeyou's Avatar
Also not the most DIY friendly choice.
How big is the roof in question?
BUR can be removed with a shingle tear-off tool, but it's pretty labor intensive, especially when covered with gravel.
Old 03-15-2012, 09:49 AM   #11
It is barely contractor friendly.
Please do not be attempting this roof on your own. You have a much higher than acceptable risk of burning your house down.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
OldNBroken (03-15-2012), rossfingal (03-15-2012)
Old 03-15-2012, 10:08 AM   #12
Shut in w/o Home
seeyou's Avatar
It's one of the few roofing operations we don't do. That and BUR.
Old 03-15-2012, 10:12 AM   #13
Even after 30 years of doing it I still get a bit antsy when I start a torchdown. This is about the only type of roofing that I will not give any DIY advice on. Odds are high the results will be one of two things. Either it will be installed incorrectly or, worse yet, you will burn the structure down.
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
rossfingal (03-15-2012), tinner666 (03-15-2012)
Old 03-15-2012, 10:34 AM   #14
"Nail-Bender"
Yeah -
"Torch-down" is not a "DIY" project!!
rossfingal
(I've done them enough to know - danger! - "FIRE"!)
rossfingal is offline   Reply With Quote
Old 03-15-2012, 07:26 PM   #15
Pro Slate Roofer
tinner666's Avatar
That's why I'm not offering any advice here either. Sorry.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
rossfingal (03-16-2012)
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 05:59 PM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 07:09 AM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 05:00 PM
Roofing felt mattflytx Roofing 2 09-10-2007 12:01 AM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 05:23 PM
