#1 |
best way to flash flat roof against concrete step
people,
Am planning redoing aflat roof, (has a slight pitch, of course). But, the flat roof butts up against a concrete slab (a kind of "patio), and the vertical height of the "step" is about 10". It also is quite a rough surface, making it a challenge to flash neatly. How do they do it? Also, wont water, during rain, possibly find its way BEHIND the flashing, by seepage? Then, any way to fill holes in the vertical surface to seal it? Thnaks
Alexander Pope: [a little knowledge can be a dangerous thing] |
#2 |
Roofmaster
You cant flash against the slab, unless the slab is waterproofed. The original roof membrane surely went under the slab. Very poor design with no foresight. Hopefully you left enough of a "Tail" on the original membrane extending out from below the slab to tie into. Since you don't say what the membrane is we need to know that first. How about some pictures?
To answer your second question, yes water will most definitely weep behind your flashing if you don't do this properly. I can help you if you give me some solid information. Pictures will help a lot.
" A lot of men build things, and a lot of things fall down " Last edited by jagans; 01-29-2013 at 09:08 AM. |
| The Following User Says Thank You to jagans For This Useful Post: | noquacks (01-29-2013) |
#3 |
Thanks, jagans. Will try for a picture....Meanwhile, yes, seems like a bad design. Now, I didnt destroy the old roof yet!! So, Im still in time. But, I have my doubts that the old membrane does go under the slab.
I should add- looking ahead, I wish to place ceramic tile on this slab. So, if I waterproof it with some paintable material, it will have to adhere to thin set......Double challenges.
#4 |
Roofmaster
First of all, where do you live? Do you get freeze thaw? Post your location, and some pictures. If you have a living space below that slab, I would be willing to bet that the membrane runs under that slab and is flashed at the perimeter.
" A lot of men build things, and a lot of things fall down " |
#5 | |
best way to flash flat roof against concrete stepQuote:
Oh- just remembered- my other thread! Heres the picture! Remodeling deck surface- How? See where the old wood deck butts up against the concrete on the right of the picture? Imagine that deck being gone- it will be about 10" deeper with decking and trusses removed......
#6 |
Roofmaster
I dont know what happened to my last post, I asked several questions. I assume by trusses you mean the sleepers holding up the decking planks?
We need to know what the structure is including the structural deck (Thats the one underneath) the exact type of roof membrane, probably a two ply BUR with a mineral surfaced cap sheet? How the sleepers are installed, How the hand rails are installed. etc etc. You need to do some demolition and take some pictures if you want help. Forget tile. Take a look at Hanover Prest Pavers.
| The Following User Says Thank You to jagans For This Useful Post: | noquacks (01-30-2013) |
#7 | |
I will advise asap on what holds up the roof------guesssing 2X6's also, maybe 2X8's......
#8 |
Man, here they are:
http://www.hanoverpavers.com/ arnt thos pavers HEAVY? Cant overload my roof surface with extra weight- Im at my limit right now......
#9 |
Roofmaster
Yes, they are 22.5 lbs per sq. ft. Plastic goes away with UV. Low density pavers fall apart. I thought you said you wanted to renovate this deck. Yes you would probably have to increase the design load. Considering how many people could go out there, I would build up its load carrying capacity.
We still need pictures of the edge of the slab and the roof membrane etc. You also did not tell us if you have leaks.
" A lot of men build things, and a lot of things fall down " Last edited by jagans; 01-30-2013 at 09:13 PM. |
| The Following User Says Thank You to jagans For This Useful Post: | noquacks (02-01-2013) |
#10 |
yeah, we got bad leaks! been limping along with patches that dont work. wood looks so tacky. so, how do you determined its 22.5lb/sf? doesnt that mean if a guy who is 200lbs standing withion the normal stance of 1sf or so will collapse?? curious.....
i understand you need pictures of the underneath, but since we havnt torn it apart yet (cuz we still are planning), no pictures if the innards....
Alexander Pope: [a little knowledge can be a dangerous thing] Last edited by noquacks; 02-01-2013 at 03:57 PM. |
| Display Modes | |
| Flat roof problem | sueann2012 | Roofing/Siding | 7 | 05-09-2012 03:09 PM |
| room extension: flat roof | highdeserthome | Roofing/Siding | 10 | 02-15-2012 07:03 PM |
| EPDM - flat roof to sloped roof transition | emtaboy | Roofing/Siding | 12 | 07-14-2010 01:12 AM |
| Flat roof addition - Joists connected to structure via legerboard?? | Rhino17 | Building & Construction | 2 | 09-01-2007 07:56 AM |
| Flat Roof Replacement Quote Questions | rocketmahn | Roofing/Siding | 1 | 01-02-2006 07:01 PM |
