Best Way To Fix Facia Board, Stuck/wedged Under Roofing Drip Edge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-01-2013, 11:56 AM   #1
Rewards Points: 1,062
best way to fix facia board, stuck/wedged under roofing drip edge
People,
trying to get a picture up here soon, meanwhile, in the event the picture offers limited utility, have a roten face board, 1x8, 12' long, and it just crumpled upon applying slight force. So, now, I have the portion of the 1x8 stuck/splintered
up underneath the drip edge, and geez, cant get it out since I imagine, theres more nails u8nder there impossible to accesss. maybe sawzall?
Can pop up drip edge without damaging the integrity of the roofing shingles at the drip line? How do they do it?
Thnaks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 12-01-2013, 02:09 PM   #2
roofermann's Avatar
Rewards Points: 401
Sawzall is the answer, you can GENTLY lift up the drip if needed. Try to do this when above 50f. Good luck!
roofermann is offline   Reply With Quote
The Following User Says Thank You to roofermann For This Useful Post:
noquacks (12-01-2013)
Old 12-01-2013, 02:18 PM   #3
Rewards Points: 14,300
Try cutting the nails as suggested but start at the ends and work to the middle so your not trying to support the whole length by just the end.
Old 12-01-2013, 02:22 PM   #4
good deal, people. thanks for the expert advice........only thing with sawzall, one has th be very careful not to let the tip of the oscillating saw to bump the asphalt shingles from underneath , during sawing. perforate the roofing, and more trouble. I'll be careful- maybe measure the saw length first.
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 05:04 AM
roof/wall drip edge interface? wombosi Building & Construction 1 05-15-2011 05:42 PM
"F" type Drip edge & felt overhang caybound Roofing/Siding 5 11-07-2009 07:44 AM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 09:28 PM
