-   -   Best way to find and fix a small leak (http://www.diychatroom.com/f9/best-way-find-fix-small-leak-71964/)
JakAHearts 05-24-2010 09:56 AM
Im renovating my upstairs and fixing a leaking roof wasnt in the plans but I guess it is now. :laughing:
Anyway, there is a very small leak that must only leak durning very hard drain as I hadnt noticed it until last evening thunderstorms and it has rained several times before. What is the best way to determine where the water is entering and then, is there a quick/easy fix for small "drip" leaks? I planned on redoing the entire roof in the spring of 2011 so I dont have the money for a complete new roof at the moment. Thanks for any advice.
Shane
RickyBobby 05-24-2010 11:32 AM
Best way would be to be up there during a heavy rain. If you know it leaks, try tracing upwards from where you find water. While there could be a 100 different causes, I would bet it is near a vent or chimney. Some more details on your roof (roofing material, # of layers, age, pitch, chimney?, vents, skylights, etc.) would be helpful.
Add that info and I think the people here could help a lot more. Best to address this now before some major damage is done.
Water is a tricky little SOB, can get into anywhere.
GOod luck.
Yoyizit 05-24-2010 12:30 PM
A $30 moisture meter may find the track in the wood that this leak followed, even when it isn't raining.
JakAHearts 05-25-2010 10:11 AM
Well, I didnt need a heavy rain or a moisture meter. It turns out that the flashing where my siding meets the lower roof is completely lifted along the edge that meets the shingles. Is this something I can try to bend back and glue back in place or do I need to remove it, clean under the flashing (there is a TON of dirt and debris under there) and then replace the flashing. All the shingles appear to be in decent shape still though about half a shingle is still hidden under the flashing. So aside from some nails, new flashing and roof glue, is there anything special Id need to buy or know? Thanks a ton guys.
Shane
