Best Way To Cut Corrugated Metal Panels? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 12:16 PM   #1
Rewards Points: 262
Best way to cut corrugated metal panels?
What is the best way to cut corrugated metal roofing panels? We want to use some as a ceiling element in our house. Jig saw, circular saw, power shears? What works best and neatest? This will be an interior installation with exposed edges. Thanks.
tpagel is offline   Reply With Quote
Old 06-05-2012, 12:50 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,150
Circular saw works well and give you a nice level cut. You should dress the edge to de-bur it a bit though.
Old 06-05-2012, 01:05 PM   #3
Rewards Points: 262
Thanks. Any particular blade type or tooth count?
Old 06-06-2012, 06:43 AM   #4
If it is just metal, i.e. no stone coating or other surface on it, get a standard bi-metal (small tooth like a hacksaw) blade that is for cutting multiple materials.
You can also get a fiber blade (something like a grinder blade) and it will not pull on the edges as much.
Old 06-06-2012, 07:03 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
actually if they are painted panels no manufacturer recommends cutting with a saw,but being this is on the inside not subject to weather it's probably ok
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (06-06-2012)
Old 06-08-2012, 09:56 PM   #6
Doing This Way Too Long
Rewards Points: 532
Best blade out there. Cuts like butter
Best way to cut corrugated metal panels?-fm-7-1-4in-x-36t-steel-saw-blade.jpg
OldNBroken is offline   Reply With Quote
Old 06-09-2012, 06:30 AM   #7
O&B,
Have you ever used those Tenryu blades?
Old 06-09-2012, 07:59 AM   #8
Rewards Points: 13,456
If you clamp a piece of plywood on the material to be cut for the saw to ride on as it's being cut it will not scratch the metal.
Old 06-09-2012, 09:30 AM   #9
Rewards Points: 532
Originally Posted by Windows on Wash View Post
O&B,
Yes WoW I had used the Tenryu until I found this blade. They tend to gum up fast with all the teeth and the shallow gullet and not near smooth a cut as this Oshlun. $65 for the Tenryu vs. $18 for this one. As long as you don't bind it up and bust too many teeth the Oshlun lasts quite a while. If you are good with a saw it really gives you a shear-like finish.
As long as too many teeth aren't busted out it can be resharpened too. But even if you can't resharpen it, for the price it's not a big loss.
Old 06-09-2012, 10:24 AM   #10
Rewards Points: 262
Many thanks for all the advice!
Metal roof questions Zedman53 Roofing/Siding 20 02-04-2012 11:32 AM
metal vs shingles av-geek Roofing/Siding 39 01-24-2012 04:25 PM
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 04:14 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
