Best Vinyl Siding Cleaner? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-13-2014, 09:33 AM   #1
Rewards Points: 556
I'm looking for a recommendation on a really good siding vinyl siding cleaner to be used in conjunction with my pressure washer. In the past, I've used ZEP Premium Pressure Wash and the results are okay, but not great.
Recently, I've been reading about Jomax, Mold Armor and others. So what do you recommend?
kcrossley2 is offline   Reply With Quote
Old 05-13-2014, 04:49 PM   #2
Chief Fungus Fighter
Sodium Hypochlorite 5% with a good SH compatible surfactant such as Zep or even just plain old Gain dishwashing detergent. Plain old surfactant isn't going to do that much for killing the algae and you don't want to use a lot of pressure. Use an X-Jet to inject an SH/Gain mix, then soft wash it and let the chem do the work. Water the plants below a lot both before and after. The SH degrades into salt so water water water. Tarp and put some Gypsum down afterwords for added security if you have a lot of money in foliage.
MoldBuster is offline   Reply With Quote
Old 05-14-2014, 10:51 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
30 second cleaner seems to work well
Old 05-14-2014, 11:25 PM   #4
30 Second is really expensive Bleach and TSP. Cheaper to buy Bleach and Soap and inject it into your PW. Invest in an X-Jet and you will be able to safely wash your home for years.
Old 05-15-2014, 06:08 AM   #5
Many people don't want to mess with mixing up their own stuff.
Old 05-15-2014, 07:05 AM   #6
Rewards Points: 13,694
http://sprayandforget.com/
It's worked for me long term on roofs and siding.
Old 05-16-2014, 07:33 AM   #7
Rewards Points: 556
That looks almost too good to be true.
Old 05-16-2014, 03:01 PM   #8
Rewards Points: 4,796
It's not really magic. That's basically what pressure washing companies are going to do if they clean your roof.
jeffnc is offline   Reply With Quote
Old 05-16-2014, 03:46 PM   #9
Gymschu's Avatar
Rewards Points: 822
Krud Kutter.
DIY - Vinyl Siding over Cedar Shakes rebelranger Remodeling 9 08-02-2012 09:47 AM
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
