Best Material To Patch Leaky Roof In Pa. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-25-2008, 05:58 AM   #1
Rewards Points: 81
best material to patch leaky roof in Pa.
Hi, have a leak in my ceiling in my sunroom. Don't know where it is coming from due to the wood beadboard ceiling. I am thinking it is coming from an exhaust that was put in a few yrs. ago. We have an exhaust cause there is a hot tub in the sunroom. Anyway I wanted to get some roofing patch. What is the best patch i can buy, and use in the winter in Pa? and will last a long time?
mayhem69 is offline   Reply With Quote
Old 12-25-2008, 07:56 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Black plastic roofing cement. It comes in various size cans and brands.
Wear old clothes, rubber gloves, and use a throw-away putty knife, paint stir stick, piece of yardstick or ruler, etc. as an applicator. This stuff is extremely sticky, and I usually get more on me than the roof.
It can be applied in the rain, and will stop leaks. I imagine that it should at least be "inside room temp" when you apply it though.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-25-2008, 02:44 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
We need to ID the roof material. Black mastic or whatever else you find in a can will often destroy the roof material. And it doesn't last long either.
tinner666 is offline   Reply With Quote
Old 12-27-2008, 05:54 PM   #4
Doing This Way Too Long
Rewards Points: 532
Without knowing what type of roofing you have we cannot recommend anything. Mastic is usually a last-ditch effort, temporary at best. Depending on the material it could cause more damage than good.
I am assuming you have ruled out condensation from that hot tub.
OldNBroken is offline   Reply With Quote
Old 12-27-2008, 07:18 PM   #5
Rewards Points: 81
it is just a regular shingle roof and yes it is not from the hot tub.
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Leaky Roof Repairs jfm617 Roofing/Siding 1 07-03-2007 12:43 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
