Best Material For Fascia - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-04-2009, 11:57 AM   #1
Best material for fascia
Assuming money is no object, what is the best material to replace decayed fascia, after source of water leak is eliminated?
Cedar, pressure treated lumber, Hardiplank, wood-fiber composite?
Your opinion is greatly appreciated.
Rodi is offline   Reply With Quote
Old 07-04-2009, 06:24 PM   #2
Are you going to paint it or stain it? Also, I would include pvc as well. This stuff lasts forever and holds up very well.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-05-2009, 09:48 AM   #3
MJW
A 2x6 with some nice Edco steel fascias.
MJW is offline   Reply With Quote
Old 07-05-2009, 10:56 AM   #4
I would without a doubt say pvc is the best material. Whether your fascia is exposed or capped with metal it will stand the test of time and you will be helping keep some plastic out of the landfill if you find a company that uses recycled material. The only downfall to pvc is it is a little more difficult to work with but pro's definitely out weigh con's. Good luck
roofah is offline   Reply With Quote
Old 07-05-2009, 08:15 PM   #5
Azek makes some great products. Great to work with too. A few notches above tuff board
II Weeks is offline   Reply With Quote
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
Ceiling Ventilation Fan rjordan392 HVAC 1 05-20-2009 05:41 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 07:30 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
