Best Flashing For Elec. Pole? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-27-2012, 10:08 AM   #1
Best flashing for elec. pole?
What should I do with the existing pitch pan flashing when I tear-off and re-shingle my roof? Should I leave it be, and maybe add some more pitch to the pan? It's not leaking now but it looks like it is only a matter of time before it starts!
MagicSmoker is offline   Reply With Quote
Old 06-27-2012, 10:18 AM   #2
Rewards Points: 13,456
What a mess, not sure how someone though that was a good ideas.
Your going to have to find a split boot, I've never seen one at Lowes or HD> May have to order one on line or look up roofing supplys in your local yellow pages.
Something like this.
http://www.bestmaterials.com/detail.aspx?ID=14993
That whole metal riser needs to go.
MagicSmoker (06-27-2012)
Old 06-27-2012, 10:21 AM   #3
Thanks for the reply! That's exactly what I was thinking would be best, but wasn't sure if it would be appropriate for a shingle roof. I guess I should use screws to fasten this retrofit boot on top of the shingles, with, say, neoprene flashing cement as "caulk"?
Old 06-27-2012, 10:28 AM   #4
Nope, the shingles all lay on top of the flanges, except at the botton where the flange is sat on top of the shingles.
Just sticking it to the roof is a sure way to have water run under the flange once the tar drys out.
Old 06-27-2012, 10:33 AM   #5
Should look like this when done.
http://images.search.yahoo.com/image...mb=Xwi4JCiNfjZ
Old 06-27-2012, 10:44 AM   #6
Poking around that same site I found a "roof jack" retrofit collar. It's more expensive, but looks like it might work better with shingles:
http://www.bestmaterials.com/detail.aspx?ID=15665
Am I overthinking this?
Old 06-27-2012, 11:37 AM   #7
That would work fine.
Use some cheap metal snips to cut out around the hole.
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
