Best Coating - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-16-2010, 08:34 PM   #1
Best coating
I am new to this forum and to roof coating too. My handyman/painter told me to get my roof checked before he paints second floor ceilings. The front and back of the roof are slanted and covered by ceramic tiles, the mid-portion is flat and is probably black tar/asphalt. The painter told me that he paints his own roof every other year, with "roof paint". I started researching the Net and discovered that there are many different "paints": acrylic, urethane, liquid rubber, etc. In my neighborhood I never saw anything but traditional shingles or flat roofs, tar or gravel. Once I saw a white garage (flat) roof. I have no idea whether it was some kind of professional covering or was it painted white.
I have trouble finding objective information online: every company presents its product as absolutely "the best" (or the best for the money). I'd like to hear an objective info, from a professional or from DIY-er (in the latter case, a single experience counts if I hear "I used XYZ product about 10 years ago and it still looks good".
Any suggestions will be appreciated.
yuhr is offline   Reply With Quote
Old 08-16-2010, 08:51 PM   #2
Where are you located ?
Old 08-17-2010, 10:03 AM   #3
Sorry. I live in NYC.
Old 08-19-2010, 05:28 PM   #4
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Some information can be found on my website. Read that then ask any specific questions you may have and I will be happy to answer to the best of my ability: Roof coatings
The questions I have for you is: Are you looking to extend the life of your roof or are you looking for UV reflectivity?
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
wrapped wood-grain coating peeling off steel door bendem Painting 2 03-27-2010 10:00 AM
Which coating to use ? desgnr Roofing/Siding 2 06-05-2009 11:00 AM
Rust-oleum EPOXYShield Coating? tripower Flooring 4 05-19-2007 02:20 PM
Builder applies coating to plywood subfloor Christopher Building & Construction 5 12-20-2006 09:19 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
