Best Cement(brand) To Seal Asphalt Shingles To Copper Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-04-2008, 10:09 AM   #1
Location: 100 miles north of Atlanta, 20 south of Chattanooga
Best cement(brand) to seal asphalt shingles to copper valley
I promise as soon as I learn everything there is to know about roofing I will stop asking questions.
Two questions please.
1. What is the best cement for sealing asphalt shingles to copper valley metal in open valley?
Certainteed suggests SBS, SBR, or rubber based caulk.
2. What is best for brick chimney and copper flashing?
Certainteed suggests urethane.
I have deep respect of the opinions of you all who actually do this for a living so here I am.
Is NP1 good? (oops, that makes three questions)
Thanks in advance, as usual.
Have a safe day,
Alan
oldgrunt is offline   Reply With Quote
Old 12-04-2008, 07:08 PM   #2
Doing This Way Too Long
Rewards Points: 532
I've found NP1 very nice for sealing the mortar cuts for counterflashings on chimneys. I refuse to use any type of mastic in valleys. Never have had a reason to. I guess if I were going to, I'd definitely recommend an sbs modified. (Henry's 908 or the like)
OldNBroken is offline   Reply With Quote
Old 12-07-2008, 01:27 PM   #3
Commercial Roofing
AaronB's Avatar
Just bend a return into the valley sheet. No need to seal them together. A sealant can actually cause water to be pushed into the roofing system at valley locations.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 05:53 AM
CertainTeed Landmark 50 asphalt shingles Wendy Honold Roofing/Siding 113 07-03-2008 11:45 AM
Do I need flashing in the valley for woven shingles? tidal9 Roofing/Siding 3 06-06-2008 11:15 AM
Elastomeric coating for asphalt shingles? Arndavis Roofing/Siding 1 09-04-2007 10:42 PM
asphalt shingles glassman Roofing/Siding 6 10-04-2006 12:03 AM
