Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-09-2007, 08:21 AM   #1
bending shingles
I just replaced the roof shingles on my work shed. It has a gambrel roof. Where the lower slope meets the upper slope the shingles hang over about 1.5". The suns heat has taken care or the southwest side of the roof and and shingles have folded over and stuck to the tar strip. The northeast side though is blocked by lots of trees and has constant shade. The shingles are still as straight as the day I installed them. I was going to bend them and use roof cement to tack them in place but the first shingle I tried popped back up. I was going to use a heat gun on them but I'm not so sure that's a great idea.
farrington135 is offline   Reply With Quote
Old 06-09-2007, 11:34 AM   #2
Super Moderator
bending shingles
You should have used a sheet metal flashing at that change of pitch location, but since you didn't, a moderate heating with a heat gun, properly paying attention to not over-heating them, would probably do the trick.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-09-2007, 11:40 AM   #3
bending shingles
On a gambrell a profesional will break up the transition with either a drip edge and or a trim detail.
We like to use PVC composite trim like Aztek or Permatrim with a drip edge and proper overhang.
bending it around is not a good way.
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
GAF Roof... the best EdPDX Roofing 73 09-12-2011 06:53 AM
Shingles per bundle redline Roofing 11 09-11-2011 11:41 PM
cutting shingles to install gutters Chicago Bill General Discussion 2 02-27-2009 06:42 AM
Over-trimmed shingles are driving me crazy pipeguy Roofing 12 08-17-2008 05:38 PM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 09:57 AM
