Beadboard Roofing Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2011, 08:33 AM   #1
Beadboard roofing material
Wondering if it is acceptable to use 3/4" beadboad plywood on my porch roof so that I get the beadboard look underneath, but have exposed beams. I would put shingles on top of the 3/4" beadboard plywood. Is this something that people do? Is the 3/4" beadboard plywood durable enough for roofing applications? Thanks.
crhage is offline   Reply With Quote
Old 06-05-2011, 09:04 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can do that,but you need too probably hand nail the roofing on with 3/4'' roofers,the smallest gun nail i believe is 1'' and will penetrate through the beadboard sheathing
Tom Struble is offline   Reply With Quote
Old 06-05-2011, 09:37 AM   #3
What I might do is cover the 3/4" beadboard ply with 1/4" or 11/32" OSB and then use 1" or 7/8" roofing nails. Thoughts?
Old 06-05-2011, 11:53 AM   #4
even better,use the osb over it
Old 06-05-2011, 12:05 PM   #5
got an even better idea...less expensive. Use 1/4" beadboard ply first and cover that with 3/4" OSB. Save some money and get the same effect.
Old 06-05-2011, 01:55 PM   #6
you win
Old 06-06-2011, 12:19 AM   #7
Rewards Points: 1,092
plywood, not osb. any leaks, and the osb may be toast; at best, it will swell and get soft.
Old 06-06-2011, 12:38 AM   #8
osb is fine
Old 06-06-2011, 01:14 AM   #9
dry, yes. wet, no. i don't like how it does not hold screws well, either. maybe just my bad luck.
Old 06-06-2011, 09:27 AM   #10
SteelToes's Avatar
Rewards Points: 150
Originally Posted by tomstruble View Post
osb is fine
It should be renamed into JOSB = JOBS
jOb Security Board.
SteelToes is offline   Reply With Quote
Old 06-06-2011, 08:51 PM   #11
yea like that wouldn't happen to any kind of sheathing...give me a break
i have never seen osb turn to mush from intermitant wetting,but i have seen plywood delaminate
The Following User Says Thank You to Tom Struble For This Useful Post:
woodworkbykirk (04-23-2016)
Old 06-07-2011, 07:22 PM   #12
place down your boards then sheet the roof with plywood, chalk your trusses so you dont nail through into your fancy beadboard . depending on anything less then a 4-12 youll need to use ice and water underlay. but thats your discretion.
Serious Roofer is offline   Reply With Quote
Old 06-09-2011, 06:18 PM   #13
Thanks folks. Great discussion. I think I'm on track with this one.
Old 04-23-2016, 05:07 AM   #14
Rewards Points: 6
Re: Beadboard roofing material
Hello,
I know this is a very old thread, but I'm wondering how the beadboard has held up to heat being attached directly to the porch roof sheathing.
On my screen porch project, I'm considering applying 3/8" beadboard on top of the rafters, then 1/2" plywood followed by tar paper and shingles. I'm just not sure if the summer NC heat coming through the rough will damage the beadboard?
Has anyone done this?
Dangeruss is offline   Reply With Quote
Old 04-23-2016, 05:59 AM   #15
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
strubles right.. the only way osb will turn into that mess is if the roofer makes every attempt possible to make sure water does get in under the shingles and ice and water shield....
woodworkbykirk is offline   Reply With Quote
roofing material suggestions - flat commercial roof mherder79 Roofing/Siding 3 05-25-2011 09:02 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Roofing material for less than 3:12 pitch seth Roofing/Siding 5 07-21-2009 08:41 AM
Roll roofing material RedDawg454 Roofing/Siding 8 05-03-2007 06:52 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
