Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-18-2012, 11:12 PM   #16
Pro Slate Roofer
tinner666's Avatar
bay window roof
Which SS. Not steel. It doesn't lend itself well to anything but gable roofs. And the commercial looks really sucks.
Galv would rust pretty fast in the UK if I'm not mistaken. Aluminum is the same as steel, btw.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
beresford (08-20-2012)
Old 08-18-2012, 11:13 PM   #17
Pro Slate Roofer
tinner666's Avatar
bay window roof
Not to mention the pitch is fine for a FL in lead or copper.
Frank
Old 08-19-2012, 07:56 PM   #18
bay window roof
Really appreciate. Do you mean the cleat as the attached pic? I mount the cleat along the edge of the roof, just above the gutter, is that right?
Originally Posted by tinner666 View Post
Use copper cleats to hold the lead in position. About 3" wide by 5" long, 12" apart. Just hook them to the folds, drive in 2 copper nails or 3, per cleat, and fold the tab end of the cleats back over the nails.
Use felt if you want. It shouldn't hurt the lead, or your roof.
beresford is offline   Reply With Quote
Old 08-19-2012, 08:20 PM   #19
Pro Slate Roofer
tinner666's Avatar
bay window roof
Nope. Top of the panel. The word 'gutter' is used in the example to denote the water flow.
Frank
Old 08-19-2012, 08:25 PM   #20
Pro Slate Roofer
tinner666's Avatar
bay window roof
Pardon my weak effort at drawing. Red is cleat, black is current dripedge, Gray is the new lead.
Frank
Old 08-19-2012, 08:32 PM   #21
Pro Slate Roofer
tinner666's Avatar
bay window roof
If you want to fly the family and I over in a few weeks, I'll help you with it.
Frank
beresford (08-19-2012)
Old 08-19-2012, 08:42 PM   #22
Pro Slate Roofer
tinner666's Avatar
bay window roof
I figure it shouldn't cost you much more than the house did.
Frank
Old 08-19-2012, 08:46 PM   #23
bay window roof
Thank you very much. I gonna to watch your videos to get more confidence to do the job.
By the way I am currently in holiday this week by staying on the computer very late.
Have a nice holiday.
The Following User Says Thank You to beresford For This Useful Post:
tinner666 (08-19-2012)
Old 08-19-2012, 08:46 PM   #24
Pro Slate Roofer
tinner666's Avatar
bay window roof
This is a SS roof, but many details are the same. Turning the metal up the wall. Back cleating along the wall to hold the panels in place, etc. http://www.albertsroofing.com/Tin%20Roofing%20photo_gallery.htm
Frank
Old 08-20-2012, 08:54 PM   #25
bay window roof
Thanks. I will read carefully. I may have one more question at this moment.
To cover the whole roof from bottom to top it need three layers.
Should I use a single lead sheet to cover the left, front and right side of the roof for every layer?
Old 08-20-2012, 09:52 PM   #26
Pro Slate Roofer
tinner666's Avatar
bay window roof
I've been thinking about it. I believe two sheets for each panel/plane/area/facet of the bay window.
I'm inclined to think 18" 'tall' by the width of each pane, and 3" up the walls.
Thinking about the cleats too. I think you better make them from lead. Less chance of an edge cutting a hole through the lead. Try stretching them before installing them. It makes them a little stiffer. (Same way came is stretched when doing stained glass to make it less floppy and the window stiffer.)
Frank
beresford (08-22-2012)
Old 08-21-2012, 11:44 AM   #27
bay window roof
Lead makes a great roof, but if it's going to get nicked again you might have to think about getting an asphalter in.
In somes places they are even taking road signs in for selling as scrap.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
beresford (08-21-2012)
Old 08-21-2012, 12:31 PM   #28
bay window roof
Did your cable TV or satellite TV provider run that cable like it is? Kind of shoddy.
hammerlane is offline   Reply With Quote
Old 08-21-2012, 07:31 PM   #29
bay window roof
Should I use anything to cover the two bridges which join different plane, one between right and front plane, the other between left and front? It sounds a big job although it is a small area.
Old 08-21-2012, 07:36 PM   #30
bay window roof
There are several deserted cables left by former owner during his residence there since 1980s.
Attaching a screen porch roof to a round bay window? rklaus Building & Construction 3 03-14-2011 08:41 AM
Bay Window roof repair sklynstra Roofing 2 02-05-2011 03:52 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing 10 04-13-2010 11:02 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
