Bathroom Vent Thru The Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2010, 05:55 PM   #1
Bathroom vent thru the roof
I would like to vent my bathroom fan thru the roof, it's a normal 4" duct. How involved is this procedure? Is there a good chance of it leaking if not done perfectly?
What would a roofer charge for cutting the hole and sealing the vent (I would do all the ductwork inside myself)?
I'm trying to weigh my options here, the roof is pretty high
Lockeset is offline   Reply With Quote
Old 10-07-2010, 07:56 PM   #2
Rewards Points: 276
Yes there is a good chance of it leaking if it is not properly installed and flashed. You can probably do this yourself if you are armed with necessary information to do it right.
Roofers typically provide free estimates on site. I doubt many would do so over the phone or online.
Jim F is online now   Reply With Quote
Old 10-07-2010, 08:37 PM   #3
If it is a shingle roof I would charge my service call charge
(min $175),as many others probably would.A flat or low-slope roof would take a little longer.I think most companies would give you a price on the phone for that.I definitely would be cheaper doing it yourself if you think you could handle it.http://video.google.com/videoplay?do...9255397426783# maybe this would help
johnk is offline   Reply With Quote
Old 10-07-2010, 08:58 PM   #4
Registered User
Rewards Points: 5,514
If you follow that video, add a bead of caulking or roof tar alongside the hole on the bottom half, each side, leaving the bottom open to drain any wind-blown rain from the sides. Tim will have a lot of leaks from that one....
Gary
Old 10-07-2010, 09:24 PM   #5
I didn't really watch the video,I just thought it would give you the basic idea.
Old 10-08-2010, 12:16 AM   #6
Rewards Points: 956
what if the bathroom is on the 1st floor? where does it usually vent to?
federer is offline   Reply With Quote
Old 10-08-2010, 08:40 AM   #7
I ask the impossible!
Rewards Points: 692
Bathroom exhaust fans can vent through walls or the roof or soffits, soffit venting is not recommended if your attic is vented through the soffit as the humid air from the bathroom could enter the attic through the soffit vents.
WillK is offline   Reply With Quote
Old 10-08-2010, 03:59 PM   #8
Yes, it's a shingle roof.
You mentioned $175, for that price I would probably rather just pay a professional, both for the possiblity of my work leaking and the danger factor.
My roof is pretty steep and it is a normal shingle roof with one layer of shingles and plywood decking.
Out of curiosity, why would a low slope roof take longer?
Bathroom vent out /Flat roof grzy1958 Roofing/Siding 1 09-27-2010 07:41 PM
Can I vent a bathroom fan in the basement? Red Squirrel Building & Construction 6 09-22-2010 11:53 AM
Basement bathroom - Vent? dogshooter Plumbing 12 12-31-2009 04:46 PM
Removing Plumbing Vent from Roof WaldenL Roofing/Siding 5 08-24-2009 02:30 PM
hip roof vent pinkertonpv Roofing/Siding 10 10-07-2008 06:58 PM
