Bathroom Roof Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-10-2015, 10:48 AM   #1
Rewards Points: 8
Bathroom roof vent
I have a slight leak, only in very heavy rains, from my bathroom ceiling fan. I've looked up at the vent pipe sticking through the roof and noted that it has no vent cap or downward turn. There are no leaks in the attic, so I'm assuming that heavy rain results in water making its way down to the fan and into the bathroom. Should I install a cap of some type that limits water entry, or just add to 90 degree elbows so that the opening points downward?
keith7481 is offline   Reply With Quote
Old 07-10-2015, 11:46 AM   #2
craig11152's Avatar
Rewards Points: 380
I'm wondering if the vent pipe sticking through the roof sounds like a plumbing vent not a fan vent. Is it a "tube" made of PVC or cast iron?
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 07-10-2015, 11:48 AM   #3
craig11152's Avatar
Rewards Points: 380
how about a picture?
Old 07-10-2015, 12:15 PM   #4
Rewards Points: 8
PVC tube, when I looked in from the attic, it looked like it was coming up from the fan. Where else would the fan vent?
Old 07-10-2015, 12:33 PM   #5
craig11152's Avatar
Rewards Points: 380
a fan could vent horizontally to an exterior wall with the duct work laying on or under some insulation. If it didn't vent outside at all it wouldn't be the first time that happened. But venting a fan with PVC straight up is not normal.
The Following User Says Thank You to craig11152 For This Useful Post:
Windows on Wash (07-10-2015)
Old 07-10-2015, 12:39 PM   #6
Rewards Points: 8
Its a two family house, and I think it was built pretty cheaply, so nothing would surprise me too much. I'll double check to make sure that fan vent is going straight out. Assuming it is coming straight up out of the roof, ok to put U in it to keep water out, should cause any problems with the air flow I would think?
Old 07-10-2015, 12:48 PM   #7
craig11152's Avatar
Rewards Points: 380
If its actually venting your fan then put a u in it. But if its venting your plumbing I differ to a plumber on the wisdom of a 'U"
keith7481 (07-10-2015)
Old 07-10-2015, 12:50 PM   #8
Rewards Points: 8
Thanks Craig, will do. Probably easier just to get up on there with the fan running and see what comes out. Much appreciated.
Old 07-10-2015, 01:17 PM   #9
craig11152's Avatar
Rewards Points: 380
Old 07-12-2015, 07:26 AM   #10
Rewards Points: 954
Popular destination is soffit vent. This is not good.
The fan part can be removed. The with light and mirror, you can tell the general direction of the vent.
carpdad is offline   Reply With Quote
roof top exhaust fan vent leaking; Please help! areaman Roofing/Siding 3 12-06-2014 06:52 AM
Bathroom Vent Van Roof Flashing ddawg16 Building & Construction 3 07-11-2012 03:19 PM
How much would it cost (range) to install a vent on my roof for bathroom fans? jmcphers Off Topic 9 02-26-2012 05:37 AM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Bathroom vent out /Flat roof grzy1958 Roofing/Siding 1 09-27-2010 07:41 PM
